Who has done a fuel cell?
Discussion in 'The Garage' started by DaveCowley, Jan 12, 2003.
  1. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    Last night I burned up my fuel pump and when trying to change it today ruined the sending unit. I am looking into doing a fuel cell behind the front seat. Has anyone done this. I know that I need Lines, Fuel Cell, and Pump with variable pressure or a regulator. I have found prices on everything but the pump. Also how hard would it be to run my lines? I probably would not run a gauge because mine hasn't worked for a year and I don't really miss it. Is it dangerous to have the cell in the passenger compartment in any way? Since I know it matters I am running a TBI350 so the pump I would need would be 40-50 PSI. Does anyone know what kind of price I would be looking at for this.
    Thanks in advance /forums/images/graemlins/thumb.gif
    Dave Cowley
  2. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    i've run a fuel cell in my old jeep, but i wouldn't run it in a sealed up passenger compartment. it could be done if vented correctly, but what about sinking it through the floor enough to keep it up even with the bottom of the framerails, where the stock tank was(rear mount), then build a sealed cover over it? /forums/images/graemlins/cool.gif
  3. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    A couple guys had them this fall at Paragon- for the UCP On The Rocks Charity ride- I know Josh had one, and i think Mike did as well- they were in the "bed' of their K5's..I can't remember what their user names were on here...do a search for UCP and you'll find the page where we posted the pics etc.... or maybe PM Wayne- he organized it, sure he knows the user names
    Brandy
  4. DaveCowley
    Feb 18, 2002
    196
    Provo, UT, USA
    I really like that idea but I want to get it out in front of the rear axle for weight considerations but I may consider sinking it into the floor and sealing it off from the inside. I really like that idea.
    Dave Cowley
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Well the '72 K20 I had had the fuel tank in the cab. Asong as the rubber lines were ok I didn't have any problems with it. /forums/images/graemlins/thumb.gif
  6. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I run one in my blazer i just cut a hole in the floor and welded some 1\4" plate across the frame and droped it in. It works great i don't hit it anymore i just don't like all the room it takes up.
  7. blueturd
    blueturd Registered Member
    Dec 3, 2002
    88
    Arvada, CO
    I recently put one in mine, on the pass side rear. I was pretty wierd about having it in the cab with me, so I am planning on building a box with a lockable flap to fill it.
    To vent it I just jammed a section of 3/8 hose to it and reconnected it to the factory charcoal can. The fuel line for mine cost like $6 a foot (steel braided) so I used it sparingly.
    Let us know how it works for you! /forums/images/graemlins/usaflag.gif
