Who has herculined their interior? What to do about bolt holes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jul 16, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    If you have, what did you do about the bolt holes like where the seats bolt to and stuff? How did you make it so the bolts would still go in the holes? Thanks!
    Dawson
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    More than one way to do it. Can oil the hole then put bolts in, then tape up the exposed part of the bolt.. Could probably even grease them, but I think that would be messier.
  3. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I rolled up some masking tape and stuck it in the holes
    and rolled around them.
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    gah, if you are gonna do the job, do it right. Remove all the "extra" bolts in your interior. I took out everything except the body mount bolts when I did my herculiner... thouroughly taped them. Pics are, as always, on my webshots! Any other herc questions, lemme know... I've used over 2 gallons of the stuff.. so far...
    J
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    they sell bags of corks in all shapes and sizes. Just stick a cork in the holes.
  6. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Just rolled up little pieces of a shop towel and stuck them in the holes. Worked out fairly well, it was quick and simple.
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I didn't herculine the inerior, I POR'd mine.
    What I did at first was to put tape on the threads and start the bolt. But then I figured out that if I wasn't a hamfist with the paint brush, I could paint around the bolt hole and not get any inside. That's what I did.
    -- Mike
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    POR isn't good if it will be exposed to sunlight as it will breakdown from the UV rays.
    I just used bolts in the bolt holes I wanted to use, after the Herculiner dried I removed the bolts and was done. Anything more would be overkill and not needed.
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I've used over three gallons so far. One on the inside and two on the outside.. I just taped over the holes..Then I used a small nail to find them again. Just tapped around tell it went threw...Dan
  10. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I just put masking tape over the holes, just make sure to pull it off before the liner sets up. I just used a small scewdriver to pull the masking tape up while the stuff was still tacky.
  11. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    real simple...the holes you want to keep put the bolts/screws in their holes, tape up the head, and go at it! wet or dry...just un-screw and you have a nice clean edge. holes you don't want to keep...tape over and forget. /forums/images/icons/smirk.gif
