Who has older toyota 4x4s.....
Discussion in 'Other Rides' started by 84CUCV, Sep 27, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Just wondering what you think of them. Found a 84, 85, and a 87. Like the 85 FI and a solid front. So what are the pros and cons of these? thx
    mike
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    be sure to check the frame area on the passenger side, behind the cab. they're notorious for rusting through there first. also, check the brake hard lines on the passenger frame rail, between the frame and gas tank. if used in mud, it will pack there and rust the line to the point that it'll rupture.
    Toyota's ifs is one of the best available, as long as the tire size is kept moderate (around 35-36 max). above that and ball joints and half-shafts suffer.
    The same can also be said for the solid axle. the newer, the better, as toyota added gussets to the front housing in the later years.
    I personally haven't found any flaws in the use of the stock carb on a toyota. if adjusted properly, it handles hills and angles as good as FI.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks for the info. mike
  4. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    I have an 87 4runner with the 22re and ifs with 33's and love it.It has been the most reliable truck I have ever had.It has 240,000 miles and I just had to replace the engine.I have seen the 22r's timing chain eat through the cover and still run.I even saw a 22r with a baseball size hole in the block and still ran.They are really tough engines.Not alot of power but that 's what the high gears are for.My runner came with 4.11's.I am upgrading to 4.88's or 5.29's in mine.I am a member over here http://www.yotatech.com/ Great info on all your toyota needs.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks for the link. 240k wow, never heard of a 350 doing that. Seen a few 6.2s do it tho.
    mike
  6. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    buddy has a couple. his baby has 230k, double TC's, everything you cvan think of--runs like a champ
    his other, "Crash" we are building cheap but strong. ill do a post as soon as we get started. its gonna be cool.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Any pics of his rig? still trying to learn about these. thanks mike
