who has "pimped" their 44 or 10b
Discussion in 'The Garage' started by SUPERSUB87, Dec 29, 2006.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    i know most people have dana 60's, but who has spent some a chunk of change making their 44's (or 10bolts) tougher. Also, how much did you spend.:crazy:
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    i think if you weighed it out, its cheaper to buy a good 60 than to invest time and money into a 10b... but this should prove interesting..
  3. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    i know, but with all the talk of 60s I feel that this is somewhat refreshing. I'm talking more about the dana 44 but you can't forget the 10b's.:D
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Love your avatar!:waytogo: :waytogo: :waytogo: :waytogo:
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Everybody says it would be cheaper to just go to a dana 60. But is it really? If you consider that you'd need new wheels to fit the lug pattern. And since those are most likely going to be 16" vs. the 15" you had before, now you need new tires.
    Or am I way off base?
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah dont buy a 60 they are stupid. let the idiots buy those up.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There have been a few hard core wheelers show up at CK5 over the years that spent upwards of $1,500 "upgrading" a 10-bolt or Dana 44. Gears, lockers, axle shafts and u-joints made from unobtanium, etc. They spent all that money only to find that there was no fix for the small ring and pinion found in those axles. :( Once the rest of the axle was unbreakable, the teeth kept getting shredded off of the ring gear. Even Wally, the uber-K5 of Off Road Design fame, started out with a beefed 10-bolt up front.
    Yes, Dana 60's cost a mint, then parts for them cost even more. However, if you wheel hard enough to keep breaking 1/2-ton stuff, you'll be dollars ahead in the long run to just start saving for a 60. It will take a LOT more abuse.
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I did a regear, warn shafts, new joints and warn premium hubs on my old K5s 10 bolt. Dumb move financially speaking... worked out well for the fellow ck5-er that bought it though. ;)
    j
  9. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    i like your thinking.:rolleyes:
  10. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    im putting warn premiums on mine as well as 3.73s. but this is my dd and for quite some time the largest that this truck will EVER see is prob a 36 (17y/o and broke):haha: Plus teh only wheeling we do around here is mud and that is one of the easier terrains stress wise. after sand lol
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    8 lug D44 or 8 lug D60...same rims. 15's will fit on the D60 with a bit of work.
    6 lug is a real waste of time IMHO, 6 small lugs and you're guaranteed a 10 or 12 bolt rear. C clip hell, semi float, small ring gear etc etc.
    That being said it always comes down to how you use the truck. Trails with 33's or 35's and a sane right foot and the 1/2 ton stuff is a bargain that'll last many years reliably.
    Rene
  12. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    well im just doin my part ot keep the demand low for those that wanna go with the 60:D
    i dont mind so much, mine's gettin squared away to gettin used here sooner or later.;)
    EDIT: and i like how you can see 2 10 bolt shafts in the lower left... both of them busted hehe. they are handy for holdin tarps down though.
  13. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    and how much did that pretty thang run ya? ive been searching for a 60 for so long and i havent had any luck so the pimped d44 is sounding better every month. but that wont get me in top truck challenge. <---( hopefully in the future.):D :o
  14. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Ok, now that that's out of the way...:D
    To me this is simple. If you're not going above 37's and you drive smart, the chromo'd D44 will be fine. Otherwise, get a 60 and a big bottle of AstroGlide (just ask MuddinManny) :eek1:. I am personally going to stick with a 10b front. My rig will never be trail only, and will never see tires larger than 35's or 37's, and I don't thrash on it. YMMV, void where prohibited, and all the other usual disclaimers apply :D
  15. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    this isnt a thread about keeping a d44 or "having/needing" to upgrade to a 60. i wanted to know how many ppl have spent x amount of $ in order to beef it up.
  16. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    the only people who beef up 44s are toyota guys:D
  17. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    I played this game once. After a complete rebuild costing close to 500 in just new parts then you add a new set of gear a rebuild kit and a detroit youve added close to 800 more into it. I stopped here thinking o ill be fine a month later I shattered the pinion. I went ona d60 search after that.
    But I have busted more rigs playin in the sand that wheeling in the texas gumbo. Sand just seems to have a lot better grip when force is applied while mud will just spin out from under you at almost any amount of acceleration , sand will in most cases hookup and can cause a hell of alot of stress on your drive terrain. I blew 3 rear ends before I got smart and built a 14ff. ANd that was onkly w/ 36's. If only I would have done some research on a 1 ton swap then .. O well ive and learn I guess..
  18. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The taller the tire, the more you need D60. The other factor is how abusive you are to your tools (K-truck). I'm running 10Bs on a Burb with 34s, 3.90:1 R&Ps, LockRight, Spicer joints, WARN premiums and hub fuse rings. Also automatic trans; it does make a difference. I bought all the parts new, my own research and labor. I research for the best price, which includes shipping if appl., and then I don't look back.:D
  19. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i paid ::GASP:: $478.00 US for my dana 60 and got a whole truck with it for free... i broke the 10 bolt in my 86 on pavement (rear axle) and the front was WELL on its way out and all we have is sugar sand and mud... if you ask me, half tons are not worth the coin to upgrade, personal preference and opinion, that's why i've been 3 years without a fsc truck, looking to build this one on as tight a budget as possible....
  20. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I have not spent tooooooo much yet on upgrades to the 10b but I have invested in gears, bearings cross over steering and 8lug conversion over the last year.(Mostly to match the back 14b) I am running 33's and will wear them out before going larger. I know it is inevitable that I will(even with the 33's) that I will tear apart the front at some point and so I will plan to get a 60. I think it is a waist of money to Bling out a 10b. if you are going to wheel hard enough that the 10b needs to be strengthened it is a waist of money and you need a 60.
    BTW I have 600 to 700$ into her alone with the cross over. but I love throwing money away:doah:
