Who has replaced their floors infront of the seats in K5
Discussion in 'The Garage' started by reddog64, Dec 9, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I need to seriously replace my floors.. I dont really have a floor to replace at this point on the one side.... Should I just cut out the old, grind down, weld in a new sheet of steel and herculine it up? /forums/images/graemlins/1zhelp.gif
    What if the supports are gone /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/eek.gif
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    LMC sells most of it...the rest is easy to fab.
    Rene
  3. reddog64
    Nov 9, 2000
    3,325
    yeah but i have a hood i can use... lol...
    I'm cheap and broke...
    Think I can cut up a hood if I dont care if it matches the floorpan...
    Just gonna get herculined...
    BTW the rear herculined is hard as a rock now and awsome!!!!
    Spilt a quart or steering fluid on it.. wiped right up /forums/images/graemlins/smile.gif /forums/images/graemlins/thumb.gif
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Well i used plain steel to fix my front floors too. It's just a bit more work. Try and copy the supports and stuff first, then sheet in the holes in the actual floor. Weld in small areas after it's all tacked down to lessen the warpage from the heat.
    Use some seam sealer before herculining it...
    Rene
  5. reddog64
    Nov 9, 2000
    3,325
    seam sealer?
    like rtv?
    Silicon? /forums/images/graemlins/confused.gif
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I used some stuff called Silaprene...it's sticks really well and stays just a little flexible without shrinking and drying over time.
    Rene
  7. reddog64
    Nov 9, 2000
    3,325
    where'd you get it...
    Do i need to use it even with teh sides welded up?
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I got a tube from my work.../forums/images/graemlins/smile.gif I just ran a thin bead over all the welded seams to make sure it was sealed up and no moisture could get in the joints. With Herc it prolly isn't necessary though.
    Rene
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I got a tube from NAPA for about $7 (cant remember exactly) when I did my floors a couple months ago and it worked great.
  10. reddog64
    Nov 9, 2000
    3,325
    I'll do the napa visit...
    /forums/images/graemlins/cool.gif
  11. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I have a set from JC Whitney that I never installed b/c my problem ended up being under the seat. Let me know if you want them. /forums/images/graemlins/ears.gif
  12. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    Yeah, no need to be fancy. When I replaced some of the floor sections, I just got some decent gauge sheetmetal.
    Use the BFH for precision fitting /forums/images/graemlins/thumb.gif, weld it, seam seal it and give 'er a good coating of your favorite rust inhibitor.
  13. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Yeah... my floor had a bigole crack/hole rust spot where the seat bolted in.. we cleaned it out, and then we fabed a 18-20 gauges steel plate to fit in there and we riveted it on, fiberglassed over it, and bed lined it... we also had to use some galvanized steel to patch up little holes and make up parts of the "lip" around the door. And we fiberglased over all the new metal we put in and then sanded that down and bedlined it.
  14. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    umm ya i used 14 gauge for my floors......took a half a sheet /forums/images/graemlins/thumb.gif......also did rockers...fabbed my own lip for the door seal ............welded it all but never sealed it or even painted it for that matter /forums/images/graemlins/grin.gif....
  15. reddog64
    Nov 9, 2000
    3,325
    LOL!!! /forums/images/graemlins/thumb.gif
    Thanks Shane!
