Who has Roll Cage in K-5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cmoe, Jun 5, 2001.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    i want to add one to mine anyoue that has one where and how much did it run? Anything you would like mto change?
    Have you mod. it? Or shoould I build my own
    C'moe
    <font color=black>the blazer is "Back in Black"
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If you can figure out how to do it. Check out Steve Frizbes cage on Yellow feaver. One of the best looking cages I've seen in a K5
    Twiztid
  4. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    My friend, Henry (bablazer73) put a cage in his 87/73 K-5. I dunno exactly what he did, but it came out nice. Ask him what he did
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    FYI..I have one and it was built by a local pipe bender I found in the yellow pages. He built cages as a side job and did a very nice and tight job for me. I hung out with him and helped out were I could. It took a full day to doit and 300 bucks later I had a 6pt cage in my K5. Sence then I have got two kids so I now am in need of adding a rear halo for more back seat pertection.
    Good luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have the S&W cage in my truck. I have posted before but will show links agian. All ?'s are welcome.
    <A target="_blank" HREF=http://members.aol.com/_ht_a/hstelman/>http://members.aol.com/_ht_a/hstelman/</A>
    This is the link to my aol webspace. Scroll down to the pics that start with cage. There are 8 all together.
    your right. I don't understand the jeep thing!
  7. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I built mine out of 2" pipe that the local steel suplier said all the local stock cars use. I think the total cost was around $55 including buyin steel, having it bent and painting it.
    David 75K5
    http://www.goldrush.coloradok5.com
    http://www.eshoppinggui.de
    <A target="_blank" HREF=http://www.get-ne.ws>http://www.get-ne.ws</A>
    [image]http://www.extremeblazer.com/sideapproachL.jpg[/image]
  8. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If you are interested in some pics of mine here they are:
    <A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292775079>http://www.zing.com/album/pictures.html?id=4292775079</A>
    The cage cost about $600.00 fully installed. It is completly tig welded and uses the existing body mounts to tie it into the frame. The cage also extends through the dash to eliminate bends and improve strength. There is also a horizontal bar that is inside the dash. Hope this helps.
    <font color=yellow>Steve Frisbie</font color=yellow>
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Steve,
    Wow! What a project! Sweet truck but I should not be looking at it cuz my wish list is growing.
    Dave
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Nice cage Steve, do you have any pictures of how it mounts to the floor?</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  11. 85m1009
    Jul 11, 2000
    718
    Missouri
    The way it mounts to the floor is easier to explain since most parts are hidden. I replaced the floor and when I had the pan out I installed square tubing inside the body mount channels that the body mount bolts go through (four locations 2 front and 2 behind the seat) Once the floor pan was replaced a 2 " x 1/4" thick strip of plate was welded to the floor between the front and rear body mount locations to keep the cage from spreading at the bottom. The cage was welded to this strip and directly over the body mount locations. I hope this is clearer than it sounds.
  12. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Any details/pics of how it goes through the dash, and the cross bar? I really like the idea, but have concerns about the body flex--would need pretty big holes.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  13. 85m1009
    Jul 11, 2000
    718
    Missouri
    I ran the front bars down through the speaker hole on the driver's sided and made a hole to match on the passenger side. I had to notch the bottom edge of the dash on both sides. The holes are only 1/2" bigger than the tubes. With the cage tied into the body mounts there is very little flex between the body and the cage. You can see a picture of the horizontal bar in the dash if you look where the instrument cluster goes in the picture album I have listed in a previous post. The horizontal bar will not work for you if you want to maintain stock instruments and/or if you have a/c. My second choice was to run the horizontal bar just above the dash.
  14. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    there are a few pics of one i had made at a local frame shop, click the link below. final cost was $900, with the seat mounts. i will be adding to it in the near future...phase II of project money pit.
    MTPockets
    <A target="_blank" HREF=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</A>
  15. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Smittybilt has them and they are pretty cheap. Smittybilt's website is in the links section of CK5.
    Brent
