who has shaved their 60 front
Discussion in 'The Garage' started by UNCLE CRACKER, Mar 27, 2004.
  1. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    was thinking about shaving a little bit off of my dana 60 front. was wondering if anyone has done this and if you guys had pics of how much you shaved off.
  2. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Shouldnt you worry about a motor first /forums/images/graemlins/whistling.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I was looking at mine today and thought the same thing.
    Since mine often runs in jeep ruts it usually has plenty of clearance. /forums/images/graemlins/rotfl.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I shaved it and the C14FF to the bottom of the bolt head. But mostly concentrated on smoothing the bottom so there was nothing to hang on going forward or back.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yes sir.
    I gained almost 1/2". /forums/images/graemlins/grin.gif
    I grinded down past the lip to the flat spot on the bottom of the housing.
    Just make sure you pull the cover off and check every so often before you get down past .500" thickness on the bottom of the housing. Glad i thought of checking before i went further. /forums/images/graemlins/ignore.gif
  6. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    a motor would definetly help /forums/images/graemlins/tongue.gif
  7. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i took the lip off of the bottom of the housing on my front.....still has good cover strength.....and gained about 1/2 inch
  8. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    Stupid question, but does shaving the axle housing cause any structural weakness? /forums/images/graemlins/dunno.gif
  9. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    here is randyellisdesign and a shaved dana 60, he related however, that trussing for hard use is usually a good idea. [​IMG]
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It technically does but with axles like the D60 and especially the 14bff there is so much metal on the bottom that it is ok to shave them some. You don't really need 1" of metal on the bottom of the diffs unless you are dropping them really hard onto rocks all the time. Most people that I have seen keep around 1/2" of metal on the bottom and call it good.
    Harley
