who has siped their TSLs?
Discussion in 'The Garage' started by jekbrown, Jun 21, 2003.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i have 39.5x15x15 TSLs and am considering siping them. A local shop does it cheap. Question: will siping help with off-road performace in any way? these tires never see asphault... so I aint worried about on-road benefits... Im interested to know if its a good thing for offroad stuff. any thoughts/input would be appreciated. /forums/images/graemlins/laugh.gif
    j
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    siping lets the tire carcass flex more... more footprint...
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Be aware that when shops do the siping they use a machine, which will make the sipes real close to the edges of the lugs so you'll end up chunking the edges of the lugs off. It's a better idea to do it by hand and keep the sipes at least 1/2" from the edges of the lugs, and only do the middle ones.</font>
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    they do use a machine... but cant u set the width on those things? /forums/images/graemlins/confused.gif
    j
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I've siped all my swampers with a carpet knife, seems to help out noise and wear and ride wise, but I know for a fact it sure helps on the ice
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I hand siped my Q78's and really liked it. Better traction in most situations, especially we slick rocks, snow and ice, and even some increase in bite on dry rock. I'd do my 42's now but don't have the right iron anymore. Figures, we get the kick butt groovin iron and it still won't do everything I want.
    definitely do it by hand, the machine can't do it right.
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The width can be set, but it still just rolls them on so on alot of the lugs you'll end up with sipes real close to the edges. </font>
  8. 01fatboy
    01fatboy Registered Member
    Apr 25, 2003
    22
    Virginia
    I have had two sets siped. It does'nt help wear or melting of the rubber on road but it sure helps in rain and ice. When I do it again I will not go all the way to the edge because it does chunk the lugs real easy. Like others have said. I only get three years out of my TSL's but they are on the highway all the time. I drove from Alaska to Georgia and covered all types of terrain, I will do it again. /forums/images/graemlins/burb.gif
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I was under the impression that there were TWO different tecniques: Siping and Grooving:
    Siping: cutting across the tread using a very thin blade (and not removing any material) to create small slices that give better bite in snow/ice conditions. IIRC, this can also help make the tire somewhat quieter on the road. It does nothing to improve tire carcass flex, since it does not remove rubber.
    Grooving: The process of removing significant amounts of rubber from the treadblocks to make them smaller and more flexible. This has the effect of allowing the tire carcass to "wrap around" rocks when aired down, and provided better traction. IIRC, this creates more heat in the tire on the highway, and makes it noisier since there are now more "voids" to resonate???
    Anyway, just thought I'd compare my "memory" with reality! /forums/images/graemlins/grin.gif
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  11. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    You are correct Greg.
    Ken H.
  12. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    ResJoe, Carpet knife?? /forums/images/graemlins/confused.gif
    Can you shed some light on this for an ignoramoose like me?
    I'd like to add siping to my tires but don't want to spend big $$$, or even small$$$ for that matter, on a grooving iron that in my claws might make my tires worse than before.
    thanx
  13. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    1. Take a carpet knife
    2. Cut lines however you want at nominal depth all over the tread
    3. Get hand cramps
    EASY!!!
    It's really hard to cut TOO deep unless you want to spend 10 seconds a cut (400-1200 cuts total!), I usually end up goes WHAKC WHACK WAHCK randomly
    Here's Some Pics
  14. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Use a dremel cut off disc, the sipes would be a little bit wider but it would be so easy to do.
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    But you do get sick of the burning rubber smell.. /forums/images/graemlins/eek.gif
  16. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Id think those little discs would break, they're picky lil sumbitches
    I know of a guy who did grooving with a circular saw /forums/images/graemlins/shocked.gif
    For the outer lugs you could do the sawzall thing or the welder thing
    I'm gonna try the welder thing someday when I'm bored
    Good luck everyone
  17. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My 38" TSL Radials are siped. I havent torn them up or anything like I thought I would yet. I would sipe another set again.
  18. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Get a gas mask duh!
