who has the buggy spring front suspension?
Discussion in 'The Garage' started by muddysub, Aug 20, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i'm interested in doing it on my suburban. how much was it, what parts do i need, and how hard was it? oh and do you clamp them down on the road?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Marv (Springer) has it--but doesn't recommend it---he'll give you more info on it though---to my understanding it works great for flex ---BUT---if you are going up something the front end wants to unload making it a very interesting situation. Marv will tell you what its like
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'v talked to marv on this many a times, basicly it comes down to street use. if you drive on the street, can the idea, if it is a full time trailer rig, then do it. i'v wanted to do it 3 times and each time i weigh the beni's
    i'm going with the 84+xj/70'sfullsize wagoneer set up.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Bigdaddy89( ithink that was his username, man I cant remember anything!) /forums/images/icons/smile.gif had it on the front. He is out of AZ....
  5. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Whats a buggy spring front suspension? I haven't really heard anybody talk about that on here before.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    That is when you take the normal rear shackle loctation off the frame(on the front) and bolt the shackle to another leaf spring(that is only abot 12" long). Then that protion of the "buggy spring" is bolted to the frame. This allows the rear of the spring to hang down alot farther thus yielding more articulation and down droop.
    This can also be done to the rear springs.
  7. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
  8. muddysub
    Jun 23, 2001
    10,451
    489
    hmmm.. nevermind. /forums/images/icons/crazy.gif i'll just get softer springs.
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    There's a guy in Salt Lake who's Suburban has some funky front shackles. Basically, they are a triangle shape like the tow shackles you see on jeeps and stuff except longer on the bottom. on the bottom of these where the holes usually are drilled, instead of usual holes, his have like four or five inch slots where the springs can slide down under full droop. Anyway the springs rest at the stock position and he has no negative road manners with awesome flex. He wanted like $250 for a front set. Spendy, but cool!
