Who has the West Texas Off Road Hydro Assist Steering System???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Nov 26, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I would like to know how it is and with the steering and braking set up on these trucks how is it when you hit the breaks hard and need to steer what happens? Since I cant afford that now where can I get a rebuild kit for my 2wd chevy box? Thanks for the help Mike
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    We'll, i'd love to tell you that they are great but i'm a little biased /forums/images/graemlins/grin.gif. So i'll let someone else tell you how bad they suck
    I also have the kits in stock if you want me to send you one, or you can usually get them at almost any parts store.
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i too would also like to tell you how it works, but i don't have it on my k5. /forums/images/graemlins/frown.gif
    all i can tell you is that everyone that has it loves it, and the Matt over a WTOR is a great person to deal with.
    ric
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I have the kit and wish I would have bought it sooner. Do a search, it's been covered many times, and there should be some good info in past posts.
    BIGJ
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The rebuild kit from NAPA was about $12. They did have to order it in however.
  6. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i have it...just dont have the ram installed yet...i am waiting to get some highsteer arms so i only have to weld the brackets on once and be done with it...WTO rocks!
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    oh yea Matt...i sent that other steering box back to ya yesterday..dont know if lisa told ya or not..but there is a added goodie to add to your shop inside the box..(not sure if lisa would aprecate it as much as you would if ya get my drift)
  8. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I have it and I really like it. It IS a bit weird on the highway with how it handles now...but a lot of that is my soft springs and no sway bar, with soft shocks. Add all that together with the hydraulic steering and it gets a bit weird in long curves with bumpy roads, etc...but overall it is a great addition.
    One big question for you Matt - Sometimes, my system acts as if there is no "power" assist...my best example is when I go to make a u-turn - let's say I slow down to a crawl, and then when I go to crank the wheel to start the u-turn, there is no assist! I manhandle the wheel to get it to keep turning and then usually by the time I make the turn it feels normal again...seems like at low rpms it doesn't have as much power as I would like??
    Details - I have the 1.75" ram from you, you tapped my AGR 2wd box, I have a new AGR SuperPump...no leaks. I did notice that Steve Fox added fluid capacity by extending his filler neck, is this required? I was told to check the fluid level when the ram is all the way in (or the wheels to the right)...is this correct? Also, I did some of your mods listed on the website - took the washer out of the end of the piston, drilled out the orifice and stretched the spring a little.
    Any ideas?
    Thanks,
  9. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i have the fix , tap the gas /forums/images/graemlins/thumb.gif tho you have the larger one so it takes more to get it moving probly .
  10. TheLakeRat
    Nov 29, 2001
    363
    Thanks for sending that back Chaz.
    Are you tryin to get me in trouble oe what? now i'm afraid to open the box when it gets here. /forums/images/graemlins/wink.gif
  11. TheLakeRat
    Nov 29, 2001
    363
    THe problem you are having is caused by the pump back flowing when you drop to an idle after the rpm's ahve been up.
    The easiest way to fix it is to just bump the trottle but that's not a cure.
    To try and cure it you probably need to try to up the flow rate of the pump just a little.
    IS that AGR pump designed for a hydro assist kit or is it just a regular AGR super pump?
    If it's just a superpump then you can drill out that main fitting just a little and get some more flow out of it..
    That should help you problem and maybe even solve it.
  12. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Well I have had both ram system. The one from AGR and WTO. the AGR system would get pretty hard to steer when you started to work the system pretty hard and I will not talk about it leaked all the time. The WTO system is what I run now it handles the heat and does not get hard to turn when the system gots hot. The WTO also handle the rock fine what I mean is you beat the hell out of the ram with the rocks and it does not leak. So I would get the WTO system if I were you and I'am sure you will love the system. I hope this helps. /forums/images/graemlins/thumb.gif
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks for the replys Mike
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got the old system from WTO, using a 2" ram. I love it in every way but one. It seems that I can't get enough flow at idle (my TBI idles at around 600 rpm) to work the hyrdo-assist ram AND my hydro-boost brakes. I'm considering going to a smaller ram along with more mods to the pump (possibly including using 2 pumps or a smaller pulley). If you don't have hydro-boost brakes, there will be no impact on brakes due to the steering. If you, like me, have both; then you definitely need the smaller ram and may need other mods to enhance flow.
