Who has what t-case...would you change it...
Discussion in 'The Garage' started by Shagnaz, Nov 25, 2003.
  1. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I want to know what people have besides stock t-cases.
    WMS, ORD doubler, Atlas, or Klune-V
    Would you change if you could do it again.
    I am "in the air" about a added gear reduction and everything is sounding really nice and prices are pretty close.
    Please, let me know truthfully.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    WMS - Basically the same thing as the ORD Doubler.
    ORD doubler - This is what I have, great setup.
    Atlas - Cannot handle input from a high HP engine, not worth the $2500+ dollars.
    Klune-V - Nice to have a 5.1 lo, but another peice that cannot handle the big ponies.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i agree that the WMS/ORD doubler is good hardware, but the Atlas is used on lots of rigs with pretty beefy engines. I wouldnt put one behind a blown 502 or anything, but I wouldnt hesitate to put it behind my 350 or a 383. and the Klune-V? never even heard about one of the Goliath model Klune's breaking...Im sure some one has broken one, but you can say that about any truck part ever made.
    j
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have a WMS Dual Case setup in mine. I would definately recommend a Doubler (either ORD or WMS) in any Fullsize Rig. I think it has the best combination of gears for what I do here in Missouri. Make sure to Twin Stick the NP205 and add cutting brakes for more useability.
    Heres my T-cases: [​IMG]
    Clearance....
    Level Outputs/Input...
    My outputs are level with the inputs, plus the NP203 box is upside down. /forums/images/graemlins/pimp1.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    For me, I have a ORD doubler. Its nice, but I need something lower.
    Ideally, I would have gone with a WMS 3.01:1 NP203 range box, then twin stick my NP205.
    It comes down to power I guess. My 350 is not going to spin the world backward, but it won't break parts as often too, so I am stuck with lower gearing.
    With my current set-up, I'm only at 51:1 mechanical crawl (102:1 with TC factored in) but with a 3:1 203, 76:1 mechanical (152:1 TC) crawl would be achieved. this would be better for my application, since I want to not use my gas pedal at all. I have seen rigs with 160:1 with a SBC, and they kick arse. Ken (crwln73) has about this (350FI, SM465, ORD Doubler, 5.86's) and he owns.
    Other can't get low enough. 73K5tony wants a 5:1 Atlas III, so with that set up (402, SM465, Atlas III, 5.13's) he'd be at 168:1 with huge amounts of power.
    Ideally, you'd be able to "test drive" each. but a lot of people use their rigs for lots of different things, so I'd go with a dual case set up.
    p.s. There is no issue with the FS Atlas cases. If you put a BBC in front of a 21 spline Jeep version, what do you expect?
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    the atlas has only 2 choices 1:1 or 5.1:1 i have a doubler and i use the 2:1 a lot. and like zakk said you can change the 203 to 3:1 and have all kinds of options. 2:1,3:1,6:1. the atlas is lighter thou. i wouldnt change what i have, except maybe 3:1 for the 203 someday.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if u want more options, just do a 3:1 203 / atlas doubler. problem solved. /forums/images/graemlins/grin.gif
    j
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Project PITA over on the PBB board has that. thing has an insane crawl.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    wonder if anyone runs a Klune-V + Atlas combo. That'd make for hella low gearing and be relatively lightweight for a 2 "case" system...
    j
  10. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    j
    DBLAZER is running this setup I believe.
  11. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I'm running a NP203 -> NP205 via my own adaptor and WMS resplining my intermediate shaft. I haven't got my Th400 back from the tranny shop so I'm not sure how it will perform...I may eventually go to 3:1 Gears from WMS....Or just do it myself /forums/images/graemlins/thumb.gif
    The Gears are welded...and noice the price is based on "exchange on range box" So I think they're using factory gears and simply re-arranging them and welding them back onto another specified shaft...As long as I can find what combo they're using, I can *easily* reproduce what they've done with just a little care.
  12. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    In case you wanted to understand a bit more about "why" the ORD Doubler is built (and costs) the way it is....here's a link where Stephen describes the product extensively:
    Dr. Watson speaks about the Doubler design...
    Personally, whenever I look at the ORD products up close I just get this overwhelming sense that they really understand what it takes to build a quality product. All the little details are taken care of.... which makes it worth the slight premium in price. /forums/images/graemlins/deal.gif
