Who here has OE AC on their K5?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by IGOR, Jun 12, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Just thought I would get an informal poll of AC'd First Gen's
    And - does your system work?
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    My 71 has it,but no compressor or brackets.
  3. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    My K/5 has it but it is not hooked up. Maybe oneday when I am old and can't take the top off I will hook it backup. /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/ignore.gif
  4. wildbill
    wildbill Registered Member
    Jul 29, 2002
    5
    California
    My 71 K5 CST has it, and it is all hooked up.
  5. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    My 70 K5 CST has it but I am ripping it out. My 72 parts has(had) it too .. if I decide to put it back it will be a vintage air system or something like that
  6. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I had good working a/c before the engine swap. The purest in me hated to take it out along with some other parts that make the ‘72 kind of unique but that’s not the direction my trucks going in right now.
    Maybe someday I’ll get it all back in there.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My 71 CST had factory air in it.
    I "have" everything but the compressor.
    I am in the process of removing it...
    I haven't put time into it just if it is in the way it comes out. The condenser came out to put in my tranny cooler. The brackets are coming out to mount a York for OBA and the side vents are comming out for a cage.
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i took it out my 72 but my 71 will have it.
    ARQ.
  9. MikeH
    MikeH Registered Member
    Apr 5, 2001
    24
    Monument, CO. USA
    The AC in my '71 is installed and works. But I'm not saying it was cheap to keep it working right! I'm old so... need working AC - not becuase its that hot in Colorado where I live but I figure if it has factory air it should work. Now if I can just get the AC belt to stop squealing when I blast the air I'd be completely happy with it.
    MikeH
  10. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    My belt was screaming like a banshee - right before my pulley bearing seized! /forums/images/graemlins/blush.gif
  11. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    Mine was an ac truck but thanks to the previous owner it now has nOnE......
  12. Blazerholic
    Blazerholic Registered Member
    Jan 12, 2003
    77
    Latonia,KY
    My 72 K5 cst had it but no brackets or anything, and it's now my parts truck sooo.... /forums/images/graemlins/rolleyes.gif
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    me 2. I solved my problem by loosing the top. the only prob is when your cookin at a stoplight./forums/images/graemlins/grin.gif
    nathan /forums/images/graemlins/grin.gif
  14. hailey
    hailey Registered Member
    Aug 25, 2002
    32
    chattanooga, tn
    the pully on my 72 exploded the other week also. its kinda funny - I put a new pully on, and it works now. but the problem is, whenever i turn the fan switch to off, my speakers go out... kinda strange
    hailey
  15. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    I'm replaing mine with a more compact unit. I didn't work before I pulled it.
    Why are you asking?
  16. druehlman
    druehlman Registered Member
    Mar 25, 2003
    45
    Texas
    My '72 Jimmy had working AC untill the previous ownrer did an engine swap. The Jimmy still has all the parts but they are on a shelf in my shop.
    Dave Jr
  17. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    I was mainly just interested to find out how common it was...
    ntaj*eep (from this board) came over the other day and acted like I had gold under my hood with my complete factory AC setup (that doesn't work because of the seized bearing)
    So that got me wondering how common it was..
  18. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    Got it on mine. Doesn't work, but I've got all the parts. Like so many others I'll get it working someday...........maybe /forums/images/graemlins/laugh.gif
  19. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    My 72 JIMMY custom has factory AC. I converted it to R-134a, blows cold works great! But I like her with her top off;-)
  20. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    no A/C but I've got a hell of a heater sitting between the frame rails.
