Who installed a Passenger drop Atlas behind a 700R4?
Discussion in 'The Garage' started by DPI, May 11, 2006.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Well, I got my Yukon 5:13s installed and now it's time to pull the burnt 700R4 and NP241. So I am getting ready to attempt the Atlas II 4.3 install and I want to be done by Memorial day.
    Just need to know if I will have to run a two piece front shaft...
    Also need to know if there is an easy way to convert the mechanical atlas speedo to my electronic speedo.
    dp
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    yes you will need a 2 piece carrier bearing front drive shaft....my bubby just did that combo with a 700 and a 5.0 atlas with 4.10 gears in the diffs. hope this helps
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yes it does help. Got any pics of the install? Also do you know what rotation he clocked the case?
  4. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I can get pics when I go over there but he clocked it up counter clockwise totally flat. pretty sure anyways.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Whatever pictures you can get would be very appreciated.
    Thanks for the info.
