Who is running roller rockers WITH TBI ***UPDATE***???
Discussion in 'The Garage' started by fortcollinsram, Jun 4, 2004.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was just curious if anyone else has roller rockers on a TBI motor. I have a feeling that my knock sensor is picking up the ticking of my roller rockers and retarding the timing on my BBC once in a while. I really only notice it on WOT runs to like 5000rpm. It is NOT detonating at all...It does on 85 octane but has never (that I can tell) on 87 or 91.... So I was curious if anybody else has had this happen...I have the stock rockers I may throw on there to see if they make a difference...
    Update below!!!! octane problem...
    Chris
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Who is running roller rockers WITH TBI???
    why are your roller rockers ticking? if its a hydraulic cam they should be zero lash just like anything else.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Have you hooked it up to a scannner and checked if you are getting knock counts? You could also have a fuel delivery problem at WOT. Making it run a little lean. Pretty common problem with TBI.
  4. dyeager535
    26,975
    I'd seriously doubt roller rockers working properly would be anywhere near the frequency the knock sensor is listening for.
    People run gear drives on injected motors without problems, and thats a LOT more "noise" than the rockers make.
    FWIW I've got rollers on my TPI, and they aren't being picked up by the knock sensor. (same setup as TBI for knock)
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is NOT detonating at all...It does on 85 octane but has nver on 87 or 91.... So I was curious if anybody else has had this happen...I have the stock rockers I may throw on there to see if they make a difference...
    Chris
    Let me get this straight...you have the problem with 87 and not with 89 or 91 and you think it is something othen then knock?
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I did on my TPI motor, no issues with the knock sensor.
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Got rollers on my TBI'ed 383 and have no problems with the knock sensor picking them up.
  8. sjeccles
    sjeccles Registered Member
    May 13, 2001
    27
    Iowa
    I have been running rollers for a year in my 90(TBI) with no problems
  9. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    figured it out...I ran it by my buddy's shop and we hooked the scanner to it and it turns out it WAS detonating a little at WOT with the 87octane gas and the timing advance was jumping all over the place so I filled up at 1/4 tank with of 91 and it runs like a raped ape. I never really did calculat the compression so I guess it is higher than I thought...
    Thanks gang
    Chris /forums/images/graemlins/thumb.gif
