Who is running what rear shocks and how are they mounted.
Discussion in 'The Garage' started by sandawgk5, Dec 15, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The title says it all. Pics would be a bonus.
    Ira
  2. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    running procomp shocks on rear. lower brackets relocated to top of axle. works grrrreat!
  3. sandawgk5
    Oct 28, 2003
    6,881
    How long are those shocks. I am trying to get the longest I can and not bottom them out while still using the stock upper mount.
    Ira
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Pro Comps here also;)
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Shocks are whatever the longest Rancho RS5000's are...
    The top mounting point is a piece rectangular tube welded across the frame rails. The shocks mount up inside a hollowed out, boxed in notch in the tube.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have a 4inch flip , and off the shelf gabriels ( search ck5 ) in the stock mounts . These look identical to Pro Comps and some others , probably made by the same supplier anyway . One shock is mounted inverted , due to the axle tube hitting it . Have yet to move my mounts , and they seem to work allright in this application . I do know that I don't quite use them to their full potetial , as I have never unbolted my spring pack clamps .
  7. boxxerace
    boxxerace Registered Member
    Sep 26, 2002
    43
    Seattle
    Bistein 5150's 14" long.
    Stock mounts on a 14 bolt FF in rear. The front shock mounts I cut off and welded to a 1/2" plate and bolted the plate roughly 7" up into the engine compartment. This allowed me to use the longest travel shocks bilstein had besides coilover/baja stuff. Right now I have equal amount of compression and droop.
    I'll can post up some pics of you want.
    (course, I wanted to push the shocks out the farthest on the axle and as verticle as much as possible. )
  8. sandawgk5
    Oct 28, 2003
    6,881
    Will the 12 gabriels be ok for the front? I will be running 4" springs and ford cast towers. For the rear I was worried about bottoming out the 12" because the collapsed height of 18". I have to reweld my mounts so I do have some flexibility in shock length however it is 14FF and I do not want hangers hanging real low on the ends when I already got an anchor in the middle.
    Ira
