Who is using a cutting brake setup in their rig?
Discussion in 'The Garage' started by yunit, Jul 3, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Since I will be twin sticking my 205, I figured it would be a good idea to isntall a cutting brake setup to help with those tight turns on the trail, since I have stretched my wheelbase out an extra 5". /forums/images/graemlins/thinking.gif
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Dr. Watson has cuting brakes on his ORD buggy. /forums/images/graemlins/thumb.gif
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have cutting brakes on my K5 and it works great. I used a single line lock on the rear axle, but have a second one to install to make each rear caliper independant. I can shift the rear into neutral and front in lo and turn the front wheels either direction and spin right around. One of the best mods I have ever done. Expecially for the tight "Jeep Trails" here in the Midwest. /forums/images/graemlins/thumb.gif
    Oh, my line locks are Hurst Brand which are $$ (leftovers from Drag Car days). I have heard of cheaper brands working fine.
    Heres what Watson has and what I plan to switch to someday.
    http://www22.inetba.com/larrysoffroad/filecabinet/body_cnc.html
    Scroll down to the 3/4" bore cutting brakes. /forums/images/graemlins/thumb.gif
  4. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    and here comes another hi jack
    you guys have pics or ideas for the twin stick set up? mines kinda iffy at the moment.
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    WHy use Hydrolic, and not just use cables!? Mounted on Cadi calipers!? I know that they allow you to ease off, but do you do that with cutting brakes????? /forums/images/graemlins/thinking.gif
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Bump
    Same question. I was planing on useing the parking brake feature aswell.
  7. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I would use the parking brakes if I had them. A buddy of mine has had the caddies on his rig for over 2 years now and has never hooked up a single cable. He said I could buy them when he does a pinion e-brake. The cutting brake is actually cheaper than the caddies and can act as an e-brake.
