Who knows how to fix this transfer case leak?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sinchphoto, May 29, 2002.
  1. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    NP208-
    The T-case is leaking from the from a couple of the 6 bolts that hold on to the adapter. whats the best way to fix the leak? remove all 6bolts clean the case and put a new gasket in there? any help would be great!
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    ive never had that problem but that would be the first thing i would do...clean the surface real well and put a new gasket on it
    Later
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    if the bolts are loose it will leak from inside as the hole go all the way through . u can just use rtv silicone instead of a gasket.
  4. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I used grey silicone gasket maker to seal my old case after finding some of the bolts missing.Never had any problems with leaks after that.
