Who knows what size u-bolt on the dana 60 housing side?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lance, Nov 25, 2002.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I know the two on the driver's side are 3-3/8" i.d. in a 5/8" diameter u-bolt. the passenger side uses two 5/8" studs but, what about the remaining u-bolt? I did a search and couldn't locate the information I need. I have measured the housing and it appears a 4" i.d. u-bolt will work. Anybody have any confirmation of this. I've already paid my studpid tax for one screw up, can't afford any more.
    Thanks in advance,
    Lance
  2. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Has everyone already gone on vacation? Someone must know the answer to this question. BTT
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I just measured my housing this morning to get a u-bolt made. I came up with 4" ID also, so that would make it a 4 5/8" ubolt measured center to center. </font color>
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I am pretty sure that when ordering U-bolts they go by inside dimension not by center to center.
  5. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    right on 4x4HIGH
    i work in a spring shop and a u bolt is always mesured from inside.
    same for the lenght ,inside (tallest point to the end of the u bolt)
    and be sure to get the correct washer and nuts because they are not the same as a normal bolt(the washer is thicker and the nut is longer )
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have two extra of those, brand new.
    I took was an idiot and only took one ubolt to the spring shop for them to measure and make me new ones.
    I took the bigger one from the housing, failing to look at the other two. SO basically, I got two extra ubolts I don't need.
    I paid just under ten each, I'll sell it to you for $5 shipped, new, with nuts and washers.
    Or, I can just go measure it for ya.
    -- Mike
  7. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks for the offer, but I don't think I could have waited for those to be shipped. My plans are to have the truck move under it's own power by the end of this holiday weekend. So, I went down yesterday afternoon and had one made for a 4" diameter axle tube in a ten inch length with a 5/8" diameter at the local spring shop. Seems to be the one I needed. Thanks everybody for your responses.
    Lance
