who makes 14SF disc brackets?
Discussion in 'The Garage' started by beater_k20, May 12, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm going to try and trade my Grand Am off tomorrow on a 90 K1500, which i plan to convert to a straight axle front, and a 14SF rear (8 lug). i'd like to use a 14SF from a K2500 truck or burb, to keep things simple, but i'd also like to convert it to rear discs. anybody out there got a kit? what rotors and calipers does it use?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    black widow is the only one that i know of that sells a kit specificly for the 14bsf. the thing i don't like about that kit is it puts the disks inside of the axle shaft, making the rear axle about 3/4-1" narrower than it was. with the backspacing of the wheels i have, the difference stock is very noticable, i don't want to add to it.
    im going to be maing my own disk brakes for my 14bsf, the 14bff brackets are the same, just spaced alot less than the 14bsf needs to be.
  4. dyeager535
    26,975
    Aren't rear disks stock in many of them starting around 2000? I'd think that would be the best idea, bolt in regarding axle dimensions, plus stock brake stuff.
    Of course, that just assumes everything body/frame wise for cables and what not didn't change. :)
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I did a set for a guy and made a new flange for the axle to be welded on. No spacers were then required. Not a bad way to go.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    TSM makes them, too.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    blackbird customs also makes an enitre kit too.
