Who makes 6" lift front springs which will not sag ?
Discussion in '1982-Present GM Diesel' started by ambritmann, Jun 3, 2002.
  1. ambritmann
    ambritmann Registered Member
    May 20, 2002
    23
    North Carolina, USA.
    Who makes 6\" lift front springs which will not sag ?
    Am looking to lift my 82' shortbed by 6" to clear the intended 35" BFG M/T tyres. Am looking for advice on which make front springs to use, I would hate to fit a set and then have the Diesel engine make them sag quickly. For the rear I am using a pair of 56" springs from a 3/4 ton Suburban along with the 14 bolt FF axle to increase the load capacity, ORD shackle flips moved back along the frame and 2" blocks. I may use some custom spring perches as well to move the rear axle back a bit. Advice on the springs would be much appreciated.
  2. Guest66
    Guest66 Registered Member
    Jul 8, 2001
    50
    Utah
    Re: Who makes 6\" lift front springs which will not sag ?
    I have 4" pro comp springs on my 1/2 ton 6.2 Blazer, and they havent sagged @ all and its been 13 months since the lift
  3. 84ZAP62
    84ZAP62 Newbie
    Jun 7, 2002
    FLORIDA SARASOTA
    You can use the HD superlift springs which they make for the 6.2 diesel. I have them on my truck and Love it, way better ride than stock. I am running 35's on 8" wheels so they do not touch the fenders. but a small body lift will work if you want 10" wheels.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I wouldn't worry about the weight that much. Those 6.2s weight about the same as a big block. And they definitley weight less than a tall deck 427, soft rides do settle. The truck I pulled the 427 out of had about 12K miles on the 4" softrides front/rear. Fronts settled so much we took the 4" block out of the dana 60 and installed a 2" dropped pitman to level the drag link. When they were new the drag link was level with the 4" block.
