who makes a good exhaust setup?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigMan, Feb 9, 2001.
  1. BigMan
    BigMan Registered Member
    Feb 4, 2001
    35
    Jefferson, WI
    Is there any companies that make a good duel exhaust setup for my 85 blazer? Everything I sett is for an 87 and newer. What's the difference? I don't want a cat back system, I'm going headers and want true duals.
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Big, I just had a sweet exhaust system put on my 87 K5. Do you still need converts/emmissions? I have flowmaster headers 2-1/2" and ran 2-1/2' aluminized pipe all the way back. The muffler is also from flowmaster inc. Cal. and is called a street performer. It's all Stainless Steel (no fiberglass etc.) has dual inlets / outlets and sounds sweet. Having it done cost me about 5 bills here. hope this helps.
    [​IMG]<font color=red> Ride'in High In My K5! [​IMG]
  3. BigMan
    Feb 4, 2001
    35
    Jefferson, WI
    no I don't need the emisions equipment. We don't have emissions where I live. I'd keep the stuff in case thay change that though. I didn't know flowmaster made headers. Does tat dual in/ out muffler act like a crossover or are the chambers seperated inside it? I was hoping to find a system I could install myself.
  4. Storm Trooper
    Nov 24, 2000
    4,640
    I don't think so but I can call the guy back on monday. If I could bend the pipes, I would have done it myself. It's the only thing I had someone do. They probably have a web site showing it. No tests here either. You don't have a bio so I don't know what area you are in. I can take some pictures if you need me to. Good luck
  5. BigMan
    Feb 4, 2001
    35
    Jefferson, WI
    That's okay, I'l probably just install some headers, buy some mufflers and have a system bent up. I can't find any prebent systems.
    I havn't filled out the profile yet. I just found this site a few days ago when I bought my blazer. I got a link to it off of offroad.com I have jeeps but this is the first blazer I'v had since I got online.
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Check http://summitracing.com for the Dynomax setup. They are the only one's I've seen with a bolt up kit for pre 87 Blazers. I believe its a true dual kit too. I haven't heard of any experiences with these but for $129.00? (if I can remember correctly) you can't go wrong. Hope this helps.
    Rod
    BLAZER FOOD!!
  7. Storm Trooper
    Nov 24, 2000
    4,640
    If you live in Colorado, I'll give you some temporary bent pipes and new turbo mufflers for a couple of cases of beer[​IMG] and drink them with you.
  8. BigMan
    Feb 4, 2001
    35
    Jefferson, WI
    I'm in Wisconsin
  9. Storm Trooper
    Nov 24, 2000
    4,640
    Bummer,[​IMG] I'm orig. from Detroit. Someone out there with some stuff for him?
  10. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I put in a dual system form JC Whitney. It didn't fit. I had to buy S tubes from the local auto store to even some close to getting the headers to line up with the rest of the exhaust. I still ended unbolting a portion of the system and taking it to a local exhaust shop to weld it up. Around here no on would install a custom system without putting in the cats ($150 each), so I went the bolt-in route($150 total). And also for whatever reason the system doesn't sound very good. I don't know if it is my engine or their mufflers. I have a '73 Blazer, and the system had trouble fitting around the stock NP203.
  11. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    If you are not looking to spend to much, I got a walker high flow cat and a flowmaster 3" single cat-back. It sounds good, but it stinks some times. I am happy with it.
    <font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red> wkeil@home.com
