Who makes good electronic micrometers and angle finders?
Discussion in 'The Garage' started by sled_dog, Jul 24, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I suck at reading a mic. I've done it many many times and just when I think I've got it, I forget all over again. So who makes a good electronic read out micrometer? And I've used an electronic mic before, they are just fun to use, so who makes a good one of them? Thanks guys.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I think the one's we use are Mitsutoyo. Might not be the right name, I'll check tomorrow at work.
    John
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Mitutoyo makes quality gauging.
  4. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    my pops uses the same kind at his shop. never had any problems with it.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I buy nothing but Mitutoyo here.
  6. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    I know Starrett is a good one.
    Starrett
  7. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    used both of them with no problems
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Mitutoyo (Japan)
    Starrett (USA)
    Brown & Sharpe (bargain stuff made offshore, but the quality stuff is USA)
    IMO, these 3 manufacturers make the best-quality precision measuring equipment around.
    Snap-On sells Starrett stuff. Never heard anything bad about Brown & Sharpe's quality stuff. I work at Lowe's with a tool & die maker who swears by Mitutoyo, but doesn't have a problem with Starrett or B&S.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have Mitutoyo, they are not electric, but are digital, i use them all the time. i have 1-2" 2-3" 3-4", but i find i need 0-1" alot, the one i have (cheapy) needs to be recalibrated.
  10. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    If you dont use them everyday, a cheap brand will usually do. These here Digitals will work just fine for most uses. We usually get the discount catalogs at work and they have machinist sets for like $50 that come with a pair of 6" calipers, 0-1" mic, 6" scale, and a carrying case for all of it. If you are not machining, that set would probably last a lifetime(As long as you dont drop them, I have a nasty habit of leaving my calipers open after I measure something and then setting them on my box and then accidentally knocking them on the ground)
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What exactly are they for? :confused:
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Precision measuring. In my case I'd mostly use them for spindles and rotors. Haven't you ever used a micrometer in school? Like I said, I suck with them so digital is so easy. I keep forgetting to go ahead and order one.
  13. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    I've had two mitutoyo calipers go bad. I won't spend the $160 for another. If you must have a digital, try starrett. Reading a mic isn't hard, just takes practice that's all.
    Bill
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I don't think so? Maybe my school doesn't have any?
    Anyways I get what they are now. Thanks
