who makes higher volume oil pan, same depth sump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TorkDSR, Jan 29, 2003.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    who makes a higher volume oil pan, like 7-8 quarts, that has a stock sump depth? i welded the pickup onto the pump, soid like to get a pan that doesnt need an extended pickup
    thanks
    Ryan
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I used to run a 6qt corvette pan it used the same pick up as a normal pan.
    Eric
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Miloden makes them but you have to make sure the extra width will clear your front shaft. Also need to make sure you have good motor mounts because the bigger pan will make toerances much less across the cross member.
    John
