Who makes the best kit for frame fixing??
Discussion in 'The Garage' started by Skyetone, Apr 16, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    Sorry I'm kinda new...Its the old c-channel frames. ( /forums/images/icons/laugh.gif toyota /forums/images/icons/laugh.gif ) I just welded ratpack7's frame that was broke right in half at the steering box. We now are wanting to get a plate and weld it into the frame for more sapport. I now have a 70 k-5 that I will do the same to BEFORE it breaks. Anyone have company names or writeups on this?
    I know of ORD but it looks a little thin on the weld in kit. The heavy gusset looks nice but does that really solve the problems?
  2. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    pictures are always nice too.......
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    run both the weld in kit and the bolt in kit.
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I suspect the weld in kits are all the same, neither one of the two that I've put in (mine and Fox's) fit spectacularly well. The main thing I don't like about them is that when you hold them up to the frame, there is a gap where the bolts go through. That said, without spending a ton of effort on it, its probably the best way available. IMO the bolt on brace is a nice piece (and I run one), but it does not solve the problem by itself, rather, it is a good addition to the weld-in kit. There are some on this site that have cracked the frame after installing the bolt on brace.
    AFAIK, the problem is with the '73-'87/'91 trucks, and does not occur in the older ones (someone please correct me if I'm wrong, my brother has a '70).
    Steve did a write up when I put his in, try looking on the main page (Here) for a link to it. There's a nice pic of my arm in there to. /forums/images/icons/wink.gif
    Pete
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    No one makes a weld in (or bolt in) steering box brace for a 1st Gen Blazer (69-72). If you look there should be a stiffning plate in there from the factory. I have never heard of a 1st gen breaking where the steering box connects.
    If you want to fab something up...go for it.
  6. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    who else makes the kits?
