Who owns a 14 bolt ff Van Width????
Discussion in 'The Garage' started by 79Stomper, Jun 15, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    If so how do you like it and what changes did you have to do to drop it in your trucks? I have heard of changing the spring perches but not sure.
    Let me know.......
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Spring perches and shock mounts both will need to be relocated. You may also have to modify your e-brake cables to work. The spring perches are easy because you don't have to remove the old ones unless you just want too. On the van width axle, the perches are much wider than a K5. All you have to do is get some new perches ($8 pair at your local trailer supply store) and weld them on in the right spot. /forums/images/graemlins/thumb.gif
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Agreed, all I had to do was move the perches and shock mounts. I'm running rear disc so the e-brake cables weren't an issue for me.
  4. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    What is the difference witht he e-brake cables in it? I am not at all familiar with the way a van is set up.
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    what he said
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    should just be the backing plates, if it is a problem eastside has alot of 14s from truck to grab a set from /forums/images/graemlins/waytogo.gif
  7. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    If you are putting the van width in your `79 Blazer and the rear ebrake is a factory setup, you won't have any issues as the G30 vans would have the same setup. I believe it was in `84 or `85 that GM changed the e-brake style to a single cable down the drivers side with the passenger side brake cable meeting the drivers side at the rear axle. The old style is a single cable down half of the vehicle that splits to both sides before it gets to the rear axle and pulling cables that comes off each wheel on its repective side. Does that make sence? /forums/images/graemlins/dunno.gif
  8. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    My understanding is that the SRW 14bff is 67.5 inches wide WMS to WMS and that the Van is 70 inches. Can anyone running a Van one confirm this, and what is the axle tube diameter?
  9. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    you are correct, 69-70" WMS on a G30 14FF.
    axle tube diameter is 3 3/8"
  10. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    ive been looking for a van 14bolt for a while myself.Let me know if you can find more than one of them,Jake
