Who removed their clear coat of their rims...
Discussion in 'The Garage' started by Cmoe, Dec 6, 2005.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    What did you use to remove it? I was told to us Sulfuric Acid (pool acid). Anyone try it? How did it work? Any sugestions?
  2. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    never done it myself, but i have heard aircraft stripper stuff works
  3. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    yep aircraft stripper works great.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've used rocks to take mine off...
  5. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    illinois salt for 15 years works
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Do youu mean the factory wheels? If so, I accidently removed mine many years ago with a pressure washer too close to them.
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    aviation stripper or plastic media blast.... one is messy and fairly cheap... the other a little more expensive,,, if you are going to coat the wheels again media leaves no residue to wash off,,, should be able to get them blasted for under 50 bucks... less if the same people are going to re coat them
  8. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    dont use acid!...
    I tried using Muriatic Acid to clean dingy aluminum mags I had once..they started SMOKING after I applied the acid!..when I hosed them off,they were black as charcoal,and I could hear them making a crackling noise like rice crispies!..they never broke or anything,but I never trusted them either...had them glass beaded at work not long after--they had marks that resembled chains all over them..!.I suspect sulfiric acid is as bad or worse!..I'd just use paint stripper or glass bead them to get the clear coat off..New England salt removes it in a year or two here..
  9. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    a few years ago, i stripped the clearcoat off the factory aluminum allow wheels on my 94 c1500. i used a product from walmart called, "dad's easy spray". it comes in a metal can, and includes a spray bottle. it sprays fast and evenly, and sticks well since it's a gel, so you don't have to pull the wheel off. once it bubbles up the finish, just wipe it off, then rinse. didn't hurt my wheels at all and they look great.
    it doesn't hurt tires if you wipe it off promptly, but if you get it on your skin, it burns like hell in about 10 seconds. so, some latex gloves and long sleeves are a good idea.
  10. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    Oven cleaner. No joke.
  11. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Oven cleaner works great on anything but aluminum surfaces(oxidizes and pits the aluminum)..... Aircraft paint stripper does the trick.
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    Just let the guys at the tire shop crimp those little weights on them. The crimps do a great job at breaking the clear coat and the as the oxidation progresses across the wheel, more and more clear coat comes off.:rolleyes:
    Seriously, though, clear coat is paint. So remove it like you would other kinds of paint. Just make sure you replace it later.
  13. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I used aircraft stripper polished them and then recleared my rims when i painted mine they look ten times better than before i even had people think they were brand new
  14. rhino105amx
    rhino105amx 1/2 ton status
    Sep 13, 2002
    159
    Mesa, Arizona
    +1 on oven cleaner.
  15. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Isn't the brand EZ Oven Cleaner? I'm pretty sure that is the stuff. I have plans for the wheels on the truck. I have stock wheels with a polished lip, and I'd like to paint the inners black and leave the lip polished. I like the DupliColor wheel paint...I used silver on a set of wheels for the Porsche (3 were unpolished aluminum, 1 polished) once and the paint seemed pretty decent. It had lots of metal flake and seemed to spray on pretty thick without runs. All I did was 2 coats of paint and 3 coats of clear. They looked good.
  16. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I used a spray can paint stripper on my '86 Vette wheels. FWIW they're buffed and polished; no clear coat now (clear coat won't stick anymore :eek1: ).
    If you have aluminum wheels that are heavily pitted I've had good results just glass beading them, then clear coating. 'Results in a neat cast surface - looks interesting and is quick & easy. A friend did his SAAB rims this way and I did my old BMW motorcyle rims too.
