Who runs 8" lift?
Discussion in 'The Garage' started by JUNIOR-K5, Mar 31, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just want to know who runs 8" of lift and have no problems.I am in the process of getting 56" springs for the rear.They are tc 4" springs and I plan on running dyi4x shackle flip with 6" shackles for proper angle.Also what kind of front springs would you guys recommend.I notice that tc only makes up to 6".I read another post asking about 56" springs and I also asked about it but I want to know about 8" lift draw backs.I was told I would have problems with my front diff. with 8" of lift.Thanks.
  2. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Check to make sure your pinion angles are okay. Driveshaft lengths will likely need to be changed, brake lines, etc. Im not sure why the front diff specifically would give problems, unless the pinion is wrong, or you try putting blocks up front etc.
    Other companies make 8" lift springs, such as skyjacker. Or you could get extended shackles. Im building my truck with 8" springs all-around, if I had it to do over again Id do the shackle flip/extension with smaller springs.
  3. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    you said you could get extended shackles. do you by any chance know where you can get sum that will raise it an extra 2 inches?
  4. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    I know other brands make 8" springs.I got a quote on some superlift softride springs.I just wanted to hear of any recomendations.On the extended shackles you mean for front right.
  5. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    yeah. im planning on buying a 4" shackle flip kit for the rear to lift the rear 8" with my 4" 56 leafs. but i need about two inches of lift in the front and i spent all my money on the 6" lift and spring break parties. Buyers remorse is a pain in the a$$.
  6. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    You don't wanna do that. Keep in mind that for every inch longer that your shackle is, your lift height is effectively 1/2 " higher. Of course, this all depends on shackle angle but it's a good way to approximate things. If you wanted to get two inches lift from your front shackle alone, you would need an 8" plus shackle- all kinds of problems. Throw in a zero rate and make some 6" shackles out of 3/8 steel.
  7. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    On my K20, I run a ORD shackle flip/4 inch block in the rear and 8 inch Supersuck springs in the front, been that way for about 2.5 years now. Heavy duty front shackles are a good thing to consider, ditch the swaybar, it doesn't make a difference when your truck is that high. DONT BUY SUPERLIFT, get BDS or Skyjacker, I already had a set of superlift springs replaced on warranty, 2 superlift centerpins have broken and they are really stiff springs that sag like hell.. You will need new brake hoses, lengthen the rear shaft, get a high angle front shaft. I run a drop pitman arm and raised steering arm for steering correction. My 35x12.5's on 17 inch rims with 4.5 backspacing still rub the lower rear corner of the front fenders. That is all that I can think of right now, I love my setup, but am switching to BDS springs with a Zero Rate sometime soon.
  8. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    ya. ive been looking around and i think what i will do for the front is get the zero rates and get the daystar greasable shackles. the shackles claim to rais it about an inch and a half and the zero rates make up the other inch. just dont really want to go through the hassle of selling my front leafs and buying 8" ones for more. i already bought a rough country lift and it does alrite. no problems yet. i just want a 8" to fit some 38's or 39's for a lil bit better traction in the mud. but that really doesnt matter since this drought hit coastal texas.
  9. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    If you just want another inch or two for tire clearance, there's always the body lift option (yes yes, I know lol... but its only a cpl inches for a mud bogger it sounds like). Keep us posted. :)
  10. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    got a 12 inch lift on one of my trucks , no problems suprisingly. i think you will be ok with 8 :o
  11. 85gmcOD
    85gmcOD Registered Member
    Jan 24, 2006
    62
    greentown, pa
    i have a 85 3/4 ton pickup wit a skyjacker 8 inch kit... i hve the 6 in springs in the rear and took a leaf out for a little better flex.. also a 2 1/2 shacle flip and 6 inch shackles... havent got the truk on the trail yet so have no real input on what works and what doesnt... im in the process of gettin a cv shaft from had.. and i rolled the rear to match the pinion angle... and the front is a 8in spring and zero rates moved up 1 1/2 and shackels.. trying to fit 44 in boggers too
  12. mundosk5
    mundosk5 Registered Member
    May 31, 2006
    9
    booty booty land
  13. 85gmcOD
    Jan 24, 2006
    62
    greentown, pa
    whats ttt mean.. haha i dont kno i could just be retarted thanks
  14. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    To The Top
  15. koldsimer
    Jan 10, 2005
    1,480
    texas
    The turnip tally.
  16. Big Ol'Chevy
    Big Ol'Chevy Registered Member
    Dec 12, 2004
    7
    Fallon, Nevada
    Skyjacker soft ride springs aren't cheap, but I think they are the best ones on the market. I have heard that BDS springs are real good, but I have never tried them, plus they are more expensive than Skyjacker.
  17. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    8" lift, all springs...one thing to say....ain't enough...here comes 10"!
    Great ride, no wander, soft as can be, rides like a cadillac!
    Manny
  18. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Manny- Didn't realize until now that your rig's a longbed. Longbeds rock!
