WHO RUNS COWL INDUCTION HOODS?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bullet, Jun 30, 2002.
  1. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Wondering who here runs a cowl hood. Which is better Steel or fiberglass? What brand? What hieght? Gotta lose the hood ornament and add some attitude to the Jimmy for the engine swap /forums/images/icons/cool.gif Thanks for the help
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    umm, i would get a metal one if you have never worked with glass before. glass is nice but you need to know how to repair it.
    that is why i am getting a glass one. thats my job. metal cools better, can use stock hinge setup and is stronger. glass is lighter. here is a link. and get the height that you like. around 3 inches looks good to me. but i am going with 3.5.
    http://www.up22.com/
    grant
  3. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I have a fiberglass one. I just wanted to lose a little weight. /forums/images/icons/grin.gif
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    built my own hood scoop for my '77 crew cab.Sort of copied the cowl hood design.Not as long of a scoop though.I like the looks of the aftermarket cowls but didn't want to pay up the a$$ for one.It came out pretty good.Not quite done yet.Need to weld it and add some bondo and paint.I did this to let some heat out from the BB.
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Anyone have a tilt frontend on their trucks? And use them off-road?
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I`m running a steel cowl hood made by Key-part! Fit and looks great!
  7. wkasak
    wkasak Registered Member Premium Member
    Jun 28, 2002
    59
    Elkridge, Maryland
    I have been running a fiberglass cowl hood with about a 2.5/3" rise for about 4 years now. When I wanted a cowl hood the only ones I could find were fiberglass, or custom made. I wasn't impressed with the Harwood hoods because of the quality, and inability to use the factory hinges, and springs. The hood I bought is finished on both sides with metal inserts to retain the factory springs. It was made by a company out of Texas, that I doubt is still in business. I do have a few stress cracks, and has the not so flat paint look now after a few years. My advice is go with a quality fiberglass hood if weight is your major concern. Although I don't think mine weights much if any less then a metal hood, since it is two separate pieces molded together with the metal inserts. Go with the metal cowl if fitment, paint quality, and structural integrity are a priority. If I had it to do over, I would go with the new metal hoods, because weight is not an issue for me. However I am very happy with my current hood, and have no reason to replace, unless it gets damaged. Here's a pic of my hood at http://www.geocities.com/wkasak/My_Blazer_Site.html?1025528701529 Good luck.
  8. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Im thinking about cutting open the original metal hood and hand making a fiberglass scoop. Been experimenting a lot lately with fiber and it seems like it wouldn't be too hard, just time consuming. I want to get the air filter seperated from the engine bay to keep water out and get some cooler air. Best of both worlds? we'll see....
  9. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    There is a place in Rapid City, SD that make a metal cowl scoop to add to your exisiting hood. Approx. $150. Will try to find a link. Want to this for my '66, and might put one on the 'Burb. /forums/images/icons/laugh.gif
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    rodzilla is right their site is www.speedcenter.net /forums/images/icons/smile.gif /forums/images/icons/cool.gif
    they're steel cowls that you weld onto your hood, i think it's very cool.
