Who runs onboard air or some other way to air up tires on the trail?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by keith, Apr 10, 2001.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Just wondering how many have a compressor or power tank. I made my power tank today!
    79 Blazer 6"lift 35's locked/4:56 <A target="_blank" HREF=http://www.keith.coloradok5.com>http://www.keith.coloradok5.com</A>
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I've got a york w/a 2.5 gallon reserve. What size bottle did you end up going with for your power tank setup?
    BIGJ
  3. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Hey BigJ i'm putting my yoek system together.Was wondering how your system works with the 2.5 gallon tank.I could probably fit that under the hood.If i go bigger i would have too mount it somewhere else.Thanks.
  4. keith
    1,158
    La Fayette, GA
    I used the 20 lb. bottle and got the other components together and ended up around $110 total.
  5. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    I just use my a/c compressor and disconnected the hoses
    on the back and put a toggle switch and a air hose fitting on
    it. now I can use airtools. cost about $20 bucks
    whats a 4 letter word for farm wagon? (ford)
  6. crazylarry74
    crazylarry74 Registered Member
    Feb 7, 2001
    66
    Colorado
    Does anyone know where i can find directions on how to convert the a/c like slider was saying? And can you fill up tires with it or is it just for air tools? Thanks.
    Crazylarry
  7. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    yes you can fill up your tires and run tools it is a constent
    flow of air. it can't be used for ARB though as far as I know.
    A friend help me do it. He has it on his heep.We just got the
    parts from a hardware store.
  8. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    thats a pretty good idea... Have to look into it.
    Jeff
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Check this
    http://www.geocities.com/spencerhut/truck/air.htm
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  10. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    slider, that's a pretty cool idea. My question is how are you keeping the compresser lubed ?
    Ric
    WHEELIN' IS NOT A HOBBY. . . IT'S A LIFESTYLE.
  11. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    Boy do I feel like I am in the stone ages I still have the thingy that plugs into a spark plug. It works but I would have to run the piss out of the 350 to run a air tool hehehehe.
    Its time to lock them in!
  12. BIGJ
    896
    Central Arkansas
    BIGD: I put the tank inbetween the frame rails right in front of the gas tank. It works great for air tools and airing up tires. The pressure usually stays around 80-90 psi when I use it, with the compressor running. The tank is rated for 150 psi. Here are a few pics.
    BIGJ
  13. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    rockcrawler.com has a big article on this go look in the tech article - Doug
    Doug Krebs
  14. KrebsATM02
    Mar 21, 2000
    553
    Doug Krebs
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Here are the links (it is a 2 parter)
    http://www.rockcrawler.com/techreports/york_tj/part2/index.htm
    Bad Dog
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Heh.. I like it for just the air tool capability
    "Do you need help fixing that flat miss?"
    "Let me just whip out my air tools..."
    Also great if you are towing your race vehicle.
    With the setup from the pics above, does your AC still work?
  17. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    i have a cheap trick that i haven't done yet, but the welders at work are slow now, so....
    i'll have some caps welded on the ends of my nerf bars, and add a schraeder valve somewhere safe. then i need to make an air hose that'll reach both tires on one side, with the proper fitting on the ends, and i'm set.
    just air the nerf bars up before the wheeling trip, and air down the tires at will. the bars will hold enough air to refill two tires, twice.
    <font color=purple>delta9blazer</font color=purple>
    <P ID="edit"><FONT SIZE=-1>Edited by delta9blazer on 04/11/01 11:08 AM (server time).</FONT></P>
  18. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    My front bumber and nerf bars are under construction but when they are done, they will hold air.
    Insurred by Smith & Wesson
