Who runs without inner fender wells?
Discussion in 'The Garage' started by Mastiff, Apr 25, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I see it this way in magazines sometimes, and it would be incredibly convenient for working on stuff... but around here I'd end up with salt and junk on my motor, which would be bad news.
    I'm just curious though, does anyone run full time without the fender wells? How would you mount the battery tray?
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    My brother runs his that way. It's real easy to work on, but he likes to play in the Iowa mud. He definately got his money's worth by buying a K&N air filter. His engine is always caked. Not real sure how he has his battery mounted, knowing him he probably has it bungy strapped to the fender. /forums/images/graemlins/yikes.gif
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I do. But my fenders are narrowed. Went and played in the mud after i got it done. Not much got on the motor. Battery is in the tool box.
  4. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I run mine without the inner fenders. I live in Ga. so I don't have to worry much about salt but I do get plenty of dust, dirt, mud and water under the hood. No biggie, just wash it off every once in a while.
    I made new battery tray mounts using part of the original mounts. I ran a brace down to the radiator support/front crossmember. I could get pics but it really isn't too hard to figure out once you start looking at things. I will tell you that moving all the stuff that was connected to the inner fender is a whole lot more time consuming than whittling up some battery tray brackets.
    BTW, my K5 is a diesel so you might have to make sure that your spark plug wires, distibutor and coil are in good shape as was as water repellency goes. Just pressure wash everything in the egine bay good,,, then if it cranks and starts AND runs well,,, then you ain't got no worries! /forums/images/graemlins/cool.gif
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I also run like this. And I did have my battery tray bungeed up for a while. That finally gave way and I moved the battery to the back. Have it right behind the rear seats. As for the the engine getting crap all over it. Some simple green and hose once a week takes care of her. We don't have much salt on the roads down here.
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i do.. buy my fenders are narrowed too.. here's how i did my battery tray..
    bad part about that location is that you have to remove all the heater/ac stuff to do it..
  7. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I have mine under my passenger front Beard Ultra seat and cage mount.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I yanked my inner fenderwells last summer. No problems at all. Didn't effect the battery at all. Not mounted to the inner fenderwell at all on my 76 K5.
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i dont but if i did i would make some removable ones out of heavy rubber, like mudflap stuff, to go play in the mud.
