Who says 33's won't rub?
Discussion in 'The Lounge' started by newyorkin, May 15, 2002.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Who says 33\'s won\'t rub?
    Well, I had an interesting start to my day. Rushing to catch the train, I hit a giant root shaped like a ramp at about 45, rolled up the root to the tree, which resculpted the wheel to sort of a caved-in shape. The tire then travelled backward to resculpt the fender, and later went flat as all the air escaped through the nice gap under the bead.
    After my wife came and got me, drove me home to get the spare (also after we drove home again to get the floor jack), I pulled my wheel off and noticed a serious amount of play in the rotor on the spindle. So I guess I'll be doing the ball joints on that side sooner than I thought...
    I'm most pissed about the fender. The other stuff is just an inconvenience more than anything else. Body-work is not in my ability at all.
    Moral of the story:
    Don't trust what you can't see at high speed (tree roots)!
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Re: Who says 33\'s won\'t rub?
    Just sawzall the fender and it'll be just fine.... /forums/images/icons/smile.gif
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I know how ya feel. I was going through a ditch kind of crossways a little while ago and heard the tires rub bad...got out to look at the fender and it looked fine where it usually rubs, righ at the rear bottom part, so I was happy. An hour later, I saw that the tire had pushed the front of the fender almost into a 90 deg angle from where it should have been...this is with 33's and a 3" lift.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I had 33's on a 4" lift and I crinkled the fenders /forums/images/icons/shocked.gif
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can make any tire rub if you really try. With my 4" lift on my Blazer and 4" lift on my Suburban I have had 35s rub, 33s rub, and even 31s rub.(BTW I didnt think 31s could rub, but with no shocks, bumps stops and no sway bar its possible /forums/images/icons/smile.gif ) I need to quit flexing out my trucks, all my fenders are pushed in at the corner, ohwell they are trucks not show cars /forums/images/icons/wink.gif
    Dan
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Yeah, but it still sucks! Especially now thumbin' my way to work, since all I hear from the front end is "Grind grind grind"...
