who says boxing in the frame was hard?
Discussion in 'The Garage' started by SCOOBYDANNN, Jun 10, 2005.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    This is officially my second customer.
    all done with the body on and everything hooked up. we are about half way done and the only thing moved moved was the fuel/brake lines.
    whatcha think?
  2. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    You did that with the body still on the frame? How long did it take you?
  3. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    looks good. but how do you get to the body mounts in case you need to get to them?
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    taking our time it has been 2 days and we are to the half way point. engine compartment will be tricky, and we're going to fix the steering box area by repairing the already cracked frame and boxing it with sleeved bolt holes.
    the guy is making it a lowrider so we are also going to box the a-arms and 4 linking the rear w/ airbags. (that won't be till later though.)
    oh, body mounts are bolted in through the top.
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    How much and what kinda performance difference will I notice? It looks cool, and I would like to box mine, but I want to know if I will really notice a big change, and if its needed.
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Put in a well designed cage tied into the frame and you will get the same effect. If I understood correctly, he was boxing the frame on a 2WD that will be using an airbag set up. That is definitely the way to go w/ a street cruiser. For 4x4 applications, I'd suggest a full cage tied into the frame. However, boxing in the front frame section where the steering box goes is a MUST IMO in all 73-89 chev pickups/SUV's. The way he is doing it sounds like it will be pretty dang stout too.
    Just my $0.02.
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    double frame...
    I saw a pulling truck a guy had--he used peices of another frame with all the brackets and hangers removed to box in the frame instead of flat plate!--he welded the 2 back to back.,so it became rectangular tube instead of a "C" channel!..it must have been very heavy...but it never broke!.. :crazy:
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Man, I'm so jealous of you southerners. That underbody is spotless compared to ours. I replaced all my brake lines 4 years ago, and 1 already rusted through the other day! Doing a box job like that, with body on is just impossible, you could never coat those welds good enough to protect from conditions here.
    Looks good though.
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    KEWL :bow:
    You must have a plasma cutter handy, huh :pimp:
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ditto! I almost crapped my pants when I saw that clean frame, under body, spring hangers! GOD I see what I am missing! :crazy:
  11. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I only wish we had a plasma, but for right now we have a well tuned oxy/ace and a few grinding disks. :D
    chevy frames are designed to flex. thats fine for normal driving and light off road. boxing the frame gets rid of almost all of it. one thing i have learned is go all or nothing. don't do just portions. i did that on my previous truck and boxing just portions ultimately killed my frame.
    i think a well designed cage AND box will be the ultimate in getting rid of frame flex. I will definately do this to my own truck.
  12. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    man i wish mine was that clean.everything has a coating of rust mixed with rusting paint.lol.nice box job.
  13. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Take some pics.. :grin:
  14. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    That is a very nice rustless frame. My body and frame has gone past the normal rust color and starting to get black. Rot is not far off.
  15. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Oh, here they are...:D
  16. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    2 whole dead threads just for that :D
  17. mudboggink5
    mudboggink5 1/2 ton status
    Mar 4, 2005
    1,736
    NEW JERSEY
    Looks good, Nice welds :thumb:
  18. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    :D Oops.
  19. m-4x4-chevy
    m-4x4-chevy Registered Member
    Feb 11, 2007
    95
    Chandler, Arizona
    Here in Arizona, you don't even have to paint things under the truck. Nothing ever rusts.
  20. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    And I thought I had a good clean frame for my project...
