Who says the cast perches on a 14b are a bitch to remove?
Discussion in 'The Garage' started by Zeus33rd, Apr 7, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I got this one off in just under 10 minutes...
    And this is the perch that I welded on to replace it..Holy Booger welds batman!!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    SO!!!!!! How'd you get it off that quickly?
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    yea come on you tease, tell us your secret.
  4. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    it took me 2 months to get the first one off!! How did you do it?
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, tell us how you got those off so quick! /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/wink.gif
    BTW, nice bead! /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    10 minutes?...What the hell? I spent close to 6 hours to get those cast SOB's off my 14 bolt!! I went through 2 grinding discs and 4 cutting discs. /forums/images/graemlins/angryfire.gif I had to cut it into little pieces and beat on it with a BFH!!
    So, what is the trick? We are all ears! /forums/images/graemlins/ears.gif
  7. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    They make these things called Plasma Cutters. They do wonderful things in very little time /forums/images/graemlins/smile.gif
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Doh! Must be nice! I'm glad someone figured it out, the grinder method really sucks! /forums/images/graemlins/thumb.gif
  9. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    cut off wheel + BFH... i think shane and I knocked both of mine off in less than 20 mins each. cheaper than a plasma... /forums/images/graemlins/tongue.gif
    j
  10. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    Hell ya, Plasma cutter and 10 min. Nice clean cuts. I even re-used mine they were in such good shape afterwords.
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    A plasma cutter would be definately be nice.
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i always thought they were far enough apart that you could just leave the old ones on there.
    oh well. . . when i bought mine i got a nice surprise and found out the perches matched! /forums/images/graemlins/grin.gif
  13. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    A little secret I learned. I did the same as a lot of you with a bunch of cutting disks and grinders at first, then I learned the secret of the portable ban saw. This thing is great, looks like two wheels with a ban-saw blade. It walked through it, tight to the axle (be careful not the let the blade drift into the housing). Definitely not a plasma cutter, but it leaves you with very little grinding afterwards too.
  14. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Great Welding Job, KidJethro!! /forums/images/graemlins/cool.gif /forums/images/graemlins/usaflag.gif
  15. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Where's all the rust /forums/images/graemlins/confused.gif!
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yeah , where is all the rust? Looks like its straight off the factory floor. Another secret? Sand blaster?
  17. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> One of the few benefits of living in Kalifornia.
  18. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The "blue wrench" worked just fine for me and mine were also reusable. Did I mention it took me about 5 minutes per side? It is amazing what you can do with a reguler cutting torch when you get good at using it. /forums/images/graemlins/thumb.gif
    Mike
  19. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Damn, lol, I forgot about this post. /forums/images/graemlins/tongue.gif
    Nope, Didn't use a Plasma cutter.../forums/images/graemlins/thumb.gif See that 9" DeWalt grinder on the table in the 1st picture? And the big ass ball peen hammer in the second picture? Thats all it took. I ground out the weld's on the ends of the perch and the one that went halfway around the axle tube only on the pumpkin side. Just gotta have a steady hand and know when to stop. Then bashed the $hit out of it from the same side. with only one side welded it only took about 10 bashes with the hammer for it to break off. NoSmog73 was standin right there when I did it. He can verify. As far as using the plasma cutter...Hard to do without gouging into the tube atleast a little bit. Easier and quicker to do it with the grinder using the method above.
    Got the rust off with a 4 1/2" grinder with a knotted cup wire wheel and about 1.5 hours of work. It sucked, I was hackin up black [censored] for a few houyrs after. I hadn't shaved for a few days so all the [censored] stuck in my wiskers...I looked like a coal miner. /forums/images/graemlins/thumb.gif
    Thank you sir. /forums/images/graemlins/thumb.gif Been to a formal welding school, and have been working as a welder/fabricator for 4 or 5 years now. I've been practicing welding with me eyes closed latley...Just listening to the sound of the arc to tell what I'm doing.
  20. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The force is strong in this one, master... /forums/images/graemlins/rotfl.gif </font>
