Who sells 15x10 8 lug black wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91gmcjimmyCH_IL, Apr 13, 2002.
  1. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I am trying to buy new wheels so I can put my one ton axle in but can't seem to find a place that sells 15x10 8 lug 4.125 backspacing wheels. The thing is I need them cheap around 50-60 dollars. If you know of a place that I can order them from I would greatly appreciate it. Thanks
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    check tire stores around your area. they might have some in the used section. i dont see anythin wrong with used wheels as long as you dotn find anything wrong with them. then get a can af krylon and make them black. flat. gloss. or mate.
    grant
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    try this one and look for a rockcrawler brand rim.
    www.4wheelparts.com or give them a call since they have much more stuff then on there website I think they are less then 50.00 shipped
  4. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I got mine at Discount. They had to order them but I got them in a few days at roughly $30 each. Mine are 15x8 but seems like they said the 15x10 was only about $10 more. Just plain white buggies. If you care what they look like, just paint them.
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Your gonna have a lot of grinding to do to get 4.125 bs to fit.Standard bs on 15x10 8 lug Eatons from Natl Tire &Wheel right now is 3.75.This is what I have and I had to grind a bit to get them to fit.Most people I know that put 15s on a 3/4 or 1 ton get between 3.5 and 3.75 bs.
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I got some used 15x10 whitespokes from another member about 2 years ago and rattle-canned then black. They still look good. BTW I run 4 1/8" backspace on a D44. I ground about halfway across the top of the caliper.
