Who sells the H4 upgrade headlight system...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Feb 11, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    A year or two ago, I read on this site about a company that sells the upgrade H4 two headlight system for older trucks, etc. I had the enclosed beam and changed it to the H4. I ordered the two light system but I now need to order a new glass housing. I can't find the name of the company. The company name I seem to recall has the name like Midnight lighting or something similar. I can't even remember what state they are in. Anyone know or recall?
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  3. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    autooptiks is where I got mine. They use a H-7 and work quite well. /forums/images/graemlins/k5.gif
  4. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    Hella makes the kit.
    Then you can up grade to hight watt bulbs.
    They make a big difference. I have had them since 93 on my 89.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I run the Bosch H4 conversion on my 84. It's the best $100 I ever spent on my truck. /forums/images/graemlins/waytogo.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I run the Hella H4 sealed beam conversion kit for my truck, and went straight with the 8100k HID kit. Like night and day, driving is so much more stress free . I dont even need supplemntal lights for offroading cause these light up the night. /forums/images/graemlins/smile.gif
    Call up Rob at http://www.fizzautosports.com
    He hooked me up real good, and he has the HID units in stock. Tell him the guy with the k5-blazer recommended you call him.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Approximate cost? /forums/images/graemlins/deal.gif
  8. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Where'd you get it?
  9. Can Can
    15,552
    136
    The local parts store deals in Bosch products. FWIW, most parts stores stock H4 stuff up here in Canada. I believe they're a little harder to find in the US because the H4 kit isn't approved by your D.O.T., although I've heard the laws differ from state to state.
  10. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I'll second the Bosch kit, bought in Canada. Another source is AutoOptiks . They've got sealed beam conversion kits from $50 plus the cost of the bulbs you choose.
  11. BEHJR
    BEHJR 1/2 ton status
    Mar 28, 2003
    141
    Plano Tx USA
    Looking at the various pages, there is no reference to the older (75) Blazers. Anyone know if there are kits available for us codgers ?? /forums/images/graemlins/1zhelp.gif
    Thanks.
    BH.
  12. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    What's involved in the install of the conversion? Does it just replae the existing bulb, or do you also wire in a relay or something?
  13. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    My AutoOptiks kit was just the bulbs and cutting off the conector and crimping on some female spades to attach to the h-7 bulb /forums/images/graemlins/grin.gif
  14. Can Can
    15,552
    136
    It's a simple job that only takes about 10 minutes a side.
    1. Remove the plastic headlight bezel
    2. Remove the chrome headlight trim ring
    3. Unplug the headlight and remove it
    4. Plug the H4 bulb into the headlight harness and hook it into the H4 housing
    5. Install the housing in place of the sealed beam headlight
    6. Reinstall the trim ring and bezel
    7. Aim the new system
    Piece of cake, brother!!!!!
  15. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    not to hijack the post but what part numbers did you use Canmore because I have an 82 and mine should be the same as yours....right.....Jason
