who thinks this will cause a problem
Discussion in 'The Garage' started by Jishory, Mar 8, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    the piece broken off of the adaptor in this picture
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I can't keep my bolts tight with all of them there. I'd hate to be short 1 to start with.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, dont think its a problem as the load would be more at the top of the adaptor since the mount is in the middle and the top of the adaptor would make a "pull effect" with the weight of the t-case and tranny on each side.
  4. dyeager535
    26,979
    I'd tend to agree that as long as you can keep the bolts tight, it probably won't hurt things to be missing.
    On another note though, is there a gasket between the adapter and that 465? It was pretty much decided that the gasket was pretty critical in regards to the tranny bearings, right? (I just noticed what looks like a bunch of sealant)
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is there enough room behind the broken part to use a large, thick washer under the bolt? That way you could at least get a bit of clamping force there.
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Better find out how/why it broke, otherwise it will repeat.
