Who used the ORD steering box support?
Discussion in 'The Garage' started by Cornfield creations, Oct 20, 2005.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I was just wondering who used the ORD steering box support bracket, not the weld on repair. Just kinda curious if it stiffened the frame up a whole lot?
    Any cons to using this setup?
  2. CK5
    May 19, 1999
    21,623
    701
    CO
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I made my own, with it on I could tell that my steering really tightened up.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I felt an improvement in my steering after I installed my brace from ORD. I highly recommend it.
    No cons to the setup that I can think of... You may have to work with the oil cooler lines, and the brakelines around the brake prop. valve, to get it to fit right, especially if you've got a bodylift. No biggie, though.
  6. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I was afraid it was not going to fit around the lines when I put mine in. However, when I finally got it up there, it was like they had used my truck for the model. My steering felt a little tighter as well. I figured it was cheap insurance against ripping holes in my frame.
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Works for me. If you haven't cracked the frame, use it and help prevent it.
    Just make sure to check it now and then to make sure it's tight.
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Just about everybody that has been on this site for any amount of time.
  9. rockspider
    rockspider Registered Member
    Sep 9, 2004
    37
    I got it too, together with ORD x-over steering conversion.
    My 1ton is abt. 5" lifted and the steering improvement over stock was amazing.
    I doublechecked the frame was crack-free before ordering the parts and feel much safer now, both offroadin' and down the road.
    Highly recommended.
  10. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I got mine when I got their xover kit too..... never drove the truck without it and lifted so dont know if anything improved... however less stress on the front has to be good.. plus my detroit, 6" leafs and 1" zero rate will put a tad of stress on the front.... :haha:
    better safe then sorry... although I didnt do the weld in patch as my frame wasnt cracked. Some recommend that patch too even if yer not cracked yet.... we will see :wink1:
  11. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    :D :bow: :laugh: good stuff . big improvment
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Good investment. Everyone I know with a Blazer has one. The other day a friend of mine broke the sector shaft on his gearbox. That kid of stress to break it would normally rip the gearbox out of the frame.
  13. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It's a must when you have crossover & big tires. It's not a matter of if you'll break the frame, it's a matter of when
    I put mine on when I did the 52" conversion & crossover.
    Mike
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    chaaa detroits dont help much either!!!! :haha:
  15. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    :haha: Good point
