Who uses a 7,000lb trailer to tow their fullsize
Discussion in 'Tow & Trailer' started by Hardcore, Jan 11, 2006.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Looking at trailers and there is a big difference in price between the 7,000 trailers and the 10,000 "equipment trailers".
    Looking at a 7,000lb , 16' car hauling trailer that weighs about 1750 lbs, has brakes on both axles. This leaves about 5,250 for my K5. Wondering if I'm pushing it.
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I know people who do it, but a 7k trailer is on the light side for a K5 and there is a good chance you will be over the limit in regards to payload on the trailer....if not over you will be right at the max.
    Most trailer places offer upgrades to the standard 7k trailer that includes the bigger axles and a bigger frame if needed (a lot of trailers I looked at were limited by the axles, not the frame). This is sometimes only a few hunderd $$ more.
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    You might be fine but I would go with the 10k which means it will have a 2 15/16 ball. If you could swing go with the 20ft trailer. I wish that I would have.
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    easy answer. buy it one time and be done with it. never need to say i should have gotten bigger. i made this mistake. my deck is to short. now i need to make it 4 ft longer and dove tail it.
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i second this one... i think my 32 foot goose neck is too short, but its not a big deal really. to me i should have goetten the 40 footer, and once i got it i would say it was to short as well. one option i should have done and HATE not doing is electric jacks.
    Grant
  6. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I bought a 18' bumper pull ( dual axle brakes, dovetail, 5" channel) to haul my John Deere 4600 tractor. Turns out it hauls my K truck very well. Its rated for 7K, and yeah its probably at its limit but it has pulled my rig as far as Jellico and back without a problem. The thing is my tractor with loader and rear attachment hooked up easily weighs as much as my trail rig, heck if it will pull the JD it will pull my truck. With the new towrig now, eventually I hope to get me a gooseneck setup later on.
    Clay
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would definantly say a 7K trailer is doable. I would go with an 18' though, My K5 was fairly close to the rear of the trailer on my 17'. You have to remember there should be at least a 10% tongue weight. That 5,250lbs that you have for your K5...525lbs of that will be on the pickup. That makes a big difference. If you don't bring your kitchen with you like some folks for an outing than all of your stuff should fit in the pickup anyway.
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I can get some pics if there is any interest. I tow my '79 K10 with 125" wheelbase and 8" lift on 44" tires which weighs around 6400 lbs on a 20' gooseneck trailer with dual 3500 lb axles. The front axle has electric brakes. I did a spring over on the trailer and the height is just right for my 2000 Ram 2500 with the Cummins. Even though I'm technically just over the capacity of my trailer axles, I'm using 2500 lb rated tires and it's really nice to have a trailer that weighs around 1700 lbs. For comparison, my friend's 25' deckover gooseneck with 5K lb axles weighs 4500 lbs...before he added the winch, air compressor, toolbox, etc. I welded 15,000 lb rated D-rings from Tractor Supply on each corner for easier tie down as well as safer and more secure attachment points.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have pulled my K5 with my fathers 20ft 7700lb trailer. His has the surge brakes which I am not real fond of, but it works good. We did alot of trailer searching before he bought this one though and it was the most heavy built trailer we could find in the size range. It also has a 2 5/16" ball....
    It's made by Performance.
  10. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    I tow my K5 on a 16' with 3500lb axles .......
    Not the best for the axles concidering my truck weighs some where around 6000lbs But it halls it without a problem. Thank god I don't have to run over the scales around here.
    Looking to upgrade to a 30' gooseneck this year.
    Heres a pic from last July on my way out to the White Knight Gathering.
    And another on a day trip out with a couple buddys
