Who uses the protection plate for the trans/flywheel?
Discussion in 'The Garage' started by wy4tt, Apr 23, 2005.
  1. wy4tt
    wy4tt 1/2 ton status
    Feb 20, 2005
    153
    USA
    I swapped out the TH350 on the Jimmy, and the new one I got didn't have the holes drilled for the original protection plate that covers the bottom of the bellhousing/flywheel. The few offroaders that I've talked to don't use them and said it wasn't necessary. What do you guys think? Should I drill some holes and reinstall the shield?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I use them and think it is neccessary. If you swamp the rig yeah it could get messy in there but if you don't have the cover its certain to be messy. Id on't know about you but I don't like the idea of mud and water squished all over the front pump seal. Also the thicker aluminum covers can add to structural integrity of the case.
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Use them. It keeps the crap out.
  4. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    If it is the big aluminum cover, that actually helps keep from cracking the bellhousing.
    Dan
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I haven't ran mine in a few years. Just never put it back on for some reason. I had the plastic one on mine when I bought it. Going to put it back on this week though as my O2 sensor wire is a little too close for my comfort. One thing hits it and will surely throw it into the convertor.
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    If you want one I have a few fer sale. PM me if you're interested. They are the heavy cast aluminum ones.
  7. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    I am converting fron a th350 to a 400 and after reading this I thought I had everything. I forgot the flywheel/converter cover. Are these heavy aluminum ones aftermarket?
  8. afroman006
    Aug 21, 2002
    2,876
    Nope factory ones.
  9. wy4tt
    Feb 20, 2005
    153
    USA
    Thanks guys. Guess I'll go ahead and tap some holes (the t350 core I got rebuilt was off a 2wd and guess they didn't have holes there). I have the alum cover from the orig, so I'm set there. It does look awfully open right now! Need to sandblast it and put some Hammerite on it. I love that stuff. Thanks again!
  10. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    I ran without one on my old th350 and cracked the housing. I don't know if that was the reason but I run one now.
  11. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    the cover might no fit correctly with the 2x4 case for the holes. and 350 -400 are same cover for the swap. and all my trucks use them.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    my rule of thumb on this one is:
    if it had struts and aluminum cover then yes run it(77-up)
    gm put struts on them for some reason i guess to reduce vertical downwards stress on front of tranny case,, even with support under t case,,, wierd.. you would thnk that would be plenty suppport..
    if no struts(76 older and especially 72 older iron ones) then dont, unless you drive where mud and water is at,
    i never run any dust shield covers on anything but then i dont have 4x4 or s-series 2wd strut kinds to drive, never have..
    ive had cars with plastic shields, and mainly all 2wd trucks from the 80s and back to into the 60s, and i never run the shields on them, i always remove them it is one of the first mods i do to them when i first get them, i dont have a sheild on the 84 c-10 3 speed or the 72 dually c-30 465 and tey are staying that way and i wont have any trouble ever out of either, just like all the others in the past, auto or manual,
    i toss them or sell them all and leave them open and never had a lick of trouble with any ever at all. no water no dirt no anything issues.,
    everyone will have an opinion on this one, it may be funny
    i say if with struts then leave it on, if not then remove it unless mud or water driving conditions,
    so if your th350 doesnt run struts then id say screw it, no worries,
    good luck
  13. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I use them all. I think it was missing on one of my vehicles, and nothing ever came of it, but I would recommend it.
  14. TucsonK5
    TucsonK5 1/2 ton status
    Apr 24, 2005
    120
    Tucson, AZ
    I always ran one after destroying my front input shaft seal on my TH350 (and subsequently frying the tranny). My 72 K5 never had one before that, but my tranny builder said it probably would have prevented it.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Basically listen to everyone else and not R72K5
    The reason the transfer case mount doesn't help the trans much is that the transfer case is hanging off the back of the adapter(leverage) and pulling down on the transmission, 24/7/365.
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have a stick, but still, i didnt have one and regretted it. Mud, water and everyhitng else got up there. Id run one.
