Who wants to see some horrible steering geometry?
Discussion in 'The Garage' started by MTMike, Apr 3, 2005.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    This is what happens when the PO corrects for 12" of suspension lift w/out going with crossover:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    From that pic it looks like both the DLE are parallel to each other which is correct. Maybe it is just the angle of that pic and they really aren't parallel but it sure looks like they are.
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    not too bad, I've seen worse.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    A raised steering arm plus a steering arm block, plus a drop draglink? Good grief!!!!!
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    huh...good eye, I didn't even see the sterring block.
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    At least the brake lines are pulled as tight as a cats tail in a rocking chair factory!!
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Now, now, I had the same setup on my blazer and it was perfectly fine. I have seen some screwed up steerings and hack jobs, but thats the correct way to correct it and works fine.
  8. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I currently have push/pull on my k5, on the street it is ok, offroad totally sucks. It is quite flexy and when flexed it goes where it wants, better have it pointed where you want to go before stuffing the tire.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  10. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    actually if you buy a 12 in kit( superlift anyway) that is what it comes with. I bought a burb from a guy that had this on it. It is a crappy set up IMO. It would push the springs back and forth before turning the tire, had 44 boggers which didn't help. And like captaininsano said..better have it pointed where you want it when off-road.
  11. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Yeah, I assumed thats what came w/ the 12" kit. It's HORRIBLE... like Rootbreaker said, it takes forever to turn. In my case, it takes 30' to turn right (just 90* turn, not a full circle) and 50' to turn left.
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why is it so "horrible"? I dont get it. My blazer turned fine with it, I could turn it with my pinky. Didnt really notice a difference after crossover, execpt the crossover was alittle harder to steer. That was with 42's.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    your draglink was too short. could've adjusted it, and it would have turned equally both ways. still a crappy setup altogether though.
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, for one, that steering arm has been heated up and bent. A normal raised steering arm is only about half that.
    Next, normal people would buy the drop pitman arm/offset draglink/raised steering arm setup to get enough steering correction... then stop there The block under the steering arm is kind of silly. There is already a boatload of stress on that upper balljoint.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    looks about the same as mine, i think the block just makes it look like its taller than it is. :dunno:
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Isn't the tie rod hole supposed to be parallel with the studs going into the knuckle?
  17. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    I totally had that problem after wheelin once in Reno moonrocks. We got back to the parking garage (yup fit barely!) and I had to go around the wrong way because I could not turn left! Well I could but it took like a city block to do so. I think the mount of the steering box is bending or something, have not figured it out, not really worried, ram soon!
  18. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    There is a dropped pitman arm thrown in there too...
  19. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    BINGO! Look at the ripple in that arm... Somebody torched it to make it fit.
