whole lot of shakin' goin' on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by myklnglo87K5, Nov 9, 2001.
  1. myklnglo87K5
    myklnglo87K5 Registered Member
    Aug 22, 2001
    10
    Kent, WA
    whole lot of shakin\' goin\' on
    I've got some overall vibration in my '87 Blazer. I've replaced all the wheel bearings, put in a new drive shaft, had wheels balanced. No lift, stock ride. It's gotten better but still has vibration. I have yet to check out the shocks which is next on my list. Can bad shocks create an overall vibration? It does seem to subside a bit on smoother roads and worse on rougher ones. It all started after putting on new rear brake drums. Everyone I've talked to says they can't be the culprit. Any ideas?
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Re: whole lot of shakin\' goin\' on
    Check the u-joints... about every bad stinking shake I get is from one of those gems decided to take a poo on me... [​IMG]
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Let me ask is it when you speed up or slow down, (5-20 mph)?
    or is it all the time?
    It could be the Transmission mounts or Motor mounts. the factory rubber could just be breaking away.
    good luck
    KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I have "heard" of cases where the drums had to be balanced (for whatever reason) in order to stop vibrations. If there is any external weights on the drums and they were put back on in a different position you will get vibes. Not sure if this is the problem because 99.9% of the time it doesn't matter which way you put the drums back on, but I have heard of a few cases where they added weights to the drum to stop vibrations (usually on the larger axles though). Again this may not be it, but would explain why just a brake job would cause vibrations. Also it could be something else (i.e. u-joint) that decided to go south at the same time you did your brake job, so check everything.
    Hope you find the cause.
    Good luck.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  5. myklnglo87K5
    Aug 22, 2001
    10
    Kent, WA
    Thanks for the input. New u-jopints with the driveshaft. I have found a bad shock bushing though, The thing is wobbling on its mount. I'll try some new shocks and rotating the shaft 180degrees. Let you know how that works. It must be a Murhpy Law that when your fixing one thing something else breaks and continues on. I did learn how to tear my front hubs apart and put them together again. That was a plus
    <P ID="edit"><FONT class="small">Edited by myklnglo87K5 on 11/10/01 12:35 AM.</FONT></P>
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    yer rotors or drums could be warped ...
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
