Whoops...
Discussion in 'The Garage' started by Drey, Apr 8, 2005.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I guess I should have changed my pads sooner, The driverside has two grooves worn in it from the rivets or whatever they are in the pad, and then one from the clip on the pad grinding. The pad is shot to hell, They needed to be changed at my last oil change but I didnt get around to it, I suppose this will teach me to put stuff off to the last minute. Also I think I have a Leaking Rear Axle Seal how much work is it to replace this, my Drum on the driverside was all full of oilly crap, and my brake resivoir is full, so IM guessing its gear oil.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah time for new rotors and pads now,
    hopefully the calipers are ok too, but you wont know til you push the pistons back in and try the truck out afterwards
    wheel seals on what axel ? 10 bolt 12 bolt ? 14 sf ? 14FF
    it matters if its an SF or FF axle
    if its an SF lke a 10 or 12 bolt thehn you gotta pull diff cover and c clip and drum and axle shaft and then you can pull wheel seal out
    good luck
  3. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    If its Stock its a 10 bolt Like before have to pull the rear cover pull the cross pin slide the axle in and remove the c clip pull axle Seals easy to change.
    90 jimmy
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Yeah, I got the Pads and everything all together yesterday, gonna have to get a new rotor next week though, I had to get back up here to college, i suppose I could pick one up here at Napa though, anyway, This is on a 96 S10 Blazer so I think thats a 10 bolt, for sure an SF.
