Who's all from AZ, & what you driving?
Discussion in 'Rocky Mountain Region' started by NoRulz, Apr 2, 2002.
  1. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    Who\'s all from AZ, & what you driving?
    since I'm newer to the board, & have only met a few... what you have, where in AZ you live, & when we gonna wheel?
    For those that don't know mine's a 78 Ford F250 supercab, shortened & sawzalled, 351(w/HEI!)/C6/ORD Doubler, D60F lockright, D70 rear ARB, somewhere around 4 or 5" of lift with 42" swampers, & I'll run almost anything.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: Who\'s all from AZ, & what you driving?
    Me
    My current Offroad truck is being parted out. Its an 86 Jimmy that I rolled six times. 350,700r4,NP208, 10 bolt front lockright 4.56 gears, 12 bolt rear mini spooled 4.56 gears, 4" lift 35s, and would run anything till I started parting it out. Its fully caged, and since I rolled it once I am not to afaid to do it again with a cage this time /forums/images/icons/smile.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    85 GMC Jimmy. 2.5" lift, 32" BFG AT's, 350 crate (300HP), 700R-4, 208, 10 bolts (auburn rear). A 14bff is in my driveway is waiting of 4.56 gears, and install. 4.56 gears and the Auburn form the rear 10 bolt are going in the front. Pics below.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Pretty much stock 84 K5 prowling the "mean streets" of Westside Tucson here!
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Dan, Are you selling the cage in your 86?
  6. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    West side Phx......'78 Blazer,350 sb, Th350(until I get the SM465/208 swapped in),3/4 ton diffs w/ 4.10's(?),4" lift with rear shackle flip,cut out fenders,no top/tailgate,15.50/38" tires.Second truck is '85 K/5 that is being built up from the frame.It will be my daily driver,305sb motor,TH350/203,10 bolts w/ 3.73's,4" lift with 35's tires.Let's get this "party started"!!! Mike
  7. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Juanblzer
    Prescott Valley, AZ (1.5 hrs. from Phoenix)
    85' K5 blazer 700r4(beefed up) np208
    350med.duty cratemotor, halfdoors,roksliders, Fullcage,beardseats, 36tsl radials on stock steelies,14blt w/detroit, D60 w/ ARB, crossover steering, tube bumpers, gutted interior, gutted heater and a/c, completely slathered in Black Durabak and Herculiner and Rustoleum Gloss spraypaint (all black). A little wrinkling from taking it where it probably shouldn't go.
    When are you all going to come up to the cool weather to wheel?
  8. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I'm north west phx and I owned my current 4x4 for 5 years now. My previous 4x4 was a 77 cj5 with a 401 and t18 tanny, that was was fun!! My cuurent truck is a 87 GMC Jimmy. Until Thankgiving 01 it was stock suspension, 32's tires, 3.73 gears, limited slip in the rear. I did install TPI on it but because of a nice lower engine knock....well it pretty much sounded like a diesel at idle, it's getting a vortec out of a 99 tahoe. I also install a 4 inch lift. TC's in front, shackle flip in the rear and long travel shocks.
    Once I get it running I have a set of 3/4 ton axles and I have a set of 35x13.5x16 Baja Claws on A/E 589's ready to go on the new axles. Unfortunately this will not be for another month or 6.
    Mike
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Yuma AZ, and i got a 74 with 2 or so inch droop(stock springs) and 33'2. 14 bolt out back with disk brakes. 350 on the pass floor, TH350 in the driver seat and a 203 part time behind the truck. once i get my house the trans will get a manual valve body and then i will put about 5 inches of lif on it. the interior is gutted and the top is going to be sold. sawsall is comming out also. need to fit 39.5's
    Grant
  10. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I'm from Tucson....... I drive an 83 blazer, 3" lift, homemade rear shackle flip. '88 350 with massive vacuum leaks, 700r4/208. 10 bolts axles with a rear LockRight, 33's and 3.73's.
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I am going to sell the frame, body without front end, and cage for 1,500 obo If anybody is interested. I still have to pull the motor and tranny out, and some other stuff.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, you know what I run but others may not so, here it is. Mine is the K30 equivalent of Matt’s (NoRulz) F350, just not as far along with respect to mods. Most of the body is gone (only cab and hood remain), 42s with 4" lift. Locked in the back (soon to be locked in the front too) with 4.56 gears. I have a modified Springer rear suspension with tons of flex. 350 TBI so no worries about the engine choking on angles.
    Near future plans include finishing my hydro assist so I can turn those 42s easier, moving the axle 2" forward, and getting a locker in that front axle.
  13. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Tempe here. I drive an 84, rig is down at the moment...need new gears, among lots of other things.
    Chris
  14. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Tucson here - I'm doing a frame off rebuild so it will be a while before it does any wheeling but I'm always looking for parts.
  15. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Who: Marv
    Where: Live in Mesa ... near Lindsay and Baseline
    What: Ugly Green Blazer, ready to do most any trail where it will fit.... tho I still only run 35" A/T's.. Don't mind new dents!
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    And some where it wont! /forums/images/icons/wink.gif
    BTW, forgot to mention, I'm on the N. side of PV, just SE of 32nd St and Shea.
  17. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Here me.
    Joey "My 7 Year old son" and I live in Phoenix, actually Awautukee. Ray Road &amp; I10.
    BTW: Joey is my wheeling buddie, he has been on every run I have ever been on, and that's lots.
    We are driving the "Robzilla". 1972 K5 Blazer that's Desert Camoed and rocking ready. It's likes the trails and is always screamming for relief.
    My motto about wheeling, "LETS DO IT, IM GAME". If the body get's in the way, get the sawsall out.
    Rob
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Forgot: Westside. 27th Ave &amp; Camelback.
  19. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    North Phx {deer valley}
    89 Blazer with all kinds of good shyt-currently for sale
    2000 polaris sportman 500-street legal
    2002 chevy crewcab HD 4x4 leveled with 33in goodyear mt/r's
  20. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    Northwest Phoenix / 87 K5 33" tires 4 inch lift L/S in rear
    8000lb Winch and a ton of extra parts for Rob .......... of course there not vacum pack yet..
