Who's arm did you use for your crossover?
Discussion in 'The Garage' started by backyardbuilt, Dec 18, 2002.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Who\'s arm did you use for your crossover?
    The arm on the passenger side knuckle not the pitman arm. And why did you use them for it strenght, cost. If I use 2 arms for hysteer can I cut off the old ones or leave them there. Thanks for your input Ryan.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: Who\'s arm did you use for your crossover?
    I got both of my arms from a guy named Steve who makes them on the side. PAid $145 for both arms and they look real good. they have the angle ground into them with the GM taper. He has a web page but I cant remember.
    theknifeman@hotmail.com
    If you want, tommarow I could throw up some pics.
  3. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Sounds good pics are good to if its not too much trouble. Thanks
  4. Re: Who\'s arm did you use for your crossover?
    i got mine from steve also, im installing it in a few days, great design though. i paid 85 shipped for the arm, and a 1" spacer
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i used the ORD arm...but its goin to be forsale here in about a week...needed a arm with 2 holes on the passanger side to do high steer..i am goin with arms from roggy enterprises.. $125 for either side drilled any way you want..ball joints 1/2 ton 1 ton or even heim joints..he will do it any way you want...but if ya dont want to go that route...you can buy mine off me in about a week or 2
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I bought mine from ORD. When I talked to Watson, he told me I had an option of buying a second arm for the left side, then using the standard ORD arm on the right side, then use a tierod with a hole for the draglink. Not real sure if this is the good setup or not. I originally had planned on buying the Avalanche arm, but Stephen talked me into buying his. He is a good salesman! /forums/images/graemlins/grin.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Isn't that the arm that twists the first time that you go wheeling, and that Avalanche won't warranty? /forums/images/graemlins/angryfire.gif Stephen stands behind the stuff that he sells, so you made a great choice! /forums/images/graemlins/thumb.gif
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    The D44 Avalanche arm is the one that I personally bent the first time out. The D60 version seems to work just fine. I have heard of no problems with the 60 version.
  9. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    I used the step-up arm from bob(roggy enterprises) works great will make any config. you want he does quality work at a very reasonable price... here is a pic of his step-up arm... [​IMG]
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That thing certainly looks beefy! /forums/images/graemlins/cool.gif
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I wouldn't buy one from them for any axle, just based on their response to customers that bent the 44 version. /forums/images/graemlins/angryfire.gif I just have a problem doing busniess with folks that won't stand behind their junk. /forums/images/graemlins/thumb.gif
  13. Chaz88K5
    2,979
    Stockton/Lodi CA
    the only thing that kinda sucks about roggy...he is hard to get ahold of..took me a few days of callin before i actully got him on the phone...he is one of the Co founders of Cal Rocs and i have worked with him on two different events...he is a great guy and will do just about anything to help ya out.
