Who's broke a bender?
Discussion in 'The Garage' started by Kyle89K5, Sep 23, 2004.
  1. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Who\'s broke a bender?
    What Brand?
    What Model?
    What Broke?
    What were you trying to bend?
    Had you mod'd the bender? i.e. hydro...
    Got pics?
    Thanks in advance folks. I'm getting real curious about bender design and I really don't want to get something that I will break...
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Re: Who\'s broke a bender?
    I've used a lot of them and never seen one break. Even the cheap benders work well if you're smart about what you are doing. One thing to remember is to keep the die lubed up or it will wear very fast.
    -Chris
  3. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Well um a friend broke the arms on mine. JD2, fully hydraulic w/ 3x24 ram. A few months ago he was bending up some tube for his cage for the race in a couple weeks from now. For some dumb reason between bends he put a pin in the wrong place and showing his wife how the bender works. Pop, broke both upper and lower main arms like nothing. /forums/images/graemlins/yikes.gif Luckly u can buy just the arms but they are $120 bucks.
    I don't think this is what you where looking for but it got broke.
    Mike
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Bent the pin in the pressure die on an M-Tech manual bender. Then again it took two guys pulling on the handle while beding 1.5" .250 wall DOM. That may have been part of it.
    edit-> M-Tech pins are7/8" or 1" (can't remeber which it is)
  5. Kyle89K5
    2,273
    OKLAHOMA
    Mike
    Was it a model 4 or a model 3 w/ hydraulics?
  6. Kyle89K5
    2,273
    OKLAHOMA
    Just the pin? Dang. Did it deform the holes or anything?
  7. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    It's a model 3.
    Mike
  8. Kyle89K5
    2,273
    OKLAHOMA
    It's a model 3.
    Mike
    /forums/images/graemlins/thumb.gif Thanks /forums/images/graemlins/grin.gif
  9. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The holes in the dies appear to be fine. The holes in the frame are wallering out a little but that is more of a use/wear thing I think.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Scott at Rock Stomper broke his. I believe it was the pin block on the end of the radius die that broke off. JD2? Not sure, drop him an email for details...
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We broke a couple of dies on our pro tools. One was the discount alum. bending 1.250x.250 wall DOM. No surprise. The other was steel but it cracked a weld on the lug on the die. Weld back up, problem solved. Same situation, bending thick stuff. We also replaced the upper and lower plates with their "HD" plates, probably due to bending thick stuff. It was never a problem with more common cage tube up to 2 x .120 wall DOM. Overall we've been happy with the pro-tools.
    The new RMD has no such problems.
  12. Kyle89K5
    2,273
    OKLAHOMA
    RMD?
    Thanks for the responses folks. In your opinion, what would you do to fix the arm problem? Is the thicker material enough? I've seen some guys gusset the back side of the arms to help with the seperation.
    Thanks again.
    KP
