whos built sliders for long beds or subs?
Discussion in 'The Garage' started by 87k10, Nov 16, 2005.
  1. 87k10
    87k10 Registered Member
    Sep 1, 2005
    31
    colorado
    i want to put sliders on a long bed but the frame isn't straight as it bends up right under the cab. does anyone have pics or a good explanation on how they attached theirs to the frame?
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Well I don't own a long bed but I do own a Pick up and my frame does the same thing. First thing I did was got rid of the saddle bag fuel tanks the pick ups come with. Attatched my slides to the frame at 3 points, the first close to the front tire is mounted to a plate welded and bolted to the frame with gussets, the other two wouldn't do that due to the frame step. I accomplished this by making 1/4 plate that dropped down to where I needed to attatch the slider runners. These were bolted to the frame with 4 grade 8 bolts using the fuel tank saddle bag mounting holes and welded a 6" x 7" gusset for strength. Believe it the frame will flex alittle but not the slides. I have come down on them very very hard many times with no problems. I felt this would be better than having the body mount bolts take ALL the punishment if I just welded them to the rocker. Oh btw, I cut out the rocker in 3 notches to the slider is level with the bottom of the rocker panel. No loss of ground clearence. Hope that helps.
    P.S. I'll try to remember to post up some pics when I get home. I'm a work now and it's lunch hour. :wink1:
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Different application, but these are the sliders I built for my tow rig.
    Oh, here's a set with steps for Ratzilla's Suburban...
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
  5. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    Here's what I was talking about
  6. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    There are two people that i know who makes them. one is Blazen91 from here and So Cal Big Dawgs. The other is Chvyhs from So Cal Big Dawgsthe website is www.scbd.org
    Look in the photo gallery in chvyhs and you can see his red sub. and a few others i believe.
