Who's converted from 52" to 56" rear springs.
Discussion in 'The Garage' started by Cmoe, Jan 23, 2005.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    What did you have to do? I have a 78 k-5...
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I run a shackle flip w/ an extended shackle and 57's... not 56's, but close enough!
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I'm thinking about not doing a shackle flip though. Thanks for the info...
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you can find a used or replica echobit style flip you just flip the brackets around backwards and change left to right . We did this on the 75 when it was Dave's , lined right up to the 56 inch springs . Just rockin the truck back and forth on the ground you could already tell it was going to be some sexy flex :D
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i did....shackle flip..with homemeade 6.5" long shackles...moved my rear hangers back 2" and the angle is good...
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Matt (az-k5) and I did this to his truck about 2 weeks ago. He had a shackle flip on the truck already (homebrew) and he just built some new longer shackles. We installed the new longer shackles and 56's and if flex's like a mother. It rides really soft to because his shackle angle is very good.
    Harley
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    P.S. I believe Jay had the echobit style on his burb with 56's and broke a shackle. I would build your own HD shackles or have someone build you a set.
    Like this but longer
    Harley
  8. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I am running the echo bit shackle flip backwards, and we were able to put in 56's
    flexy as hell!:D
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It is a killer mod. It will ride like butter and flex like crazy. You will have to have something better than the factory shock design to accomadate all of the travel. I also had to play with my e-brake cable so it wouldn't snap.
    Here is the shackle angle
    I just put some pics in my sig link of the shackle bracket and the design of the shackle. This shackle is more than over kill. I ran one with less weld surface and only 1.5 x .25 flat stock for the sides for that last 3 years with no problems and they are still being used in harley's rig. The new ones are 2 x .25" flat stock. The only reason I see to step up to 3/8" plate is for bolt hole strenght (thicker steel has less tendancy to waller out) this can easily be overcome buy just welding the correct size thick washer around the bolt hole.
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Its a great mod, I did a shackle flip as well using front hangers just moving them back.
    Just do yourself a favor and build some heavy shackles.
    This is what a stock shackle does with some mild wheeling:
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    OK, time for the usual question in a post like this one...
    What do the 56" springs come out of?
  12. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    yep and im now doing to the 74 also, but this time im using 56's out of a 3/4 ton truck(because they are free) and pulling the overload leaf out of the pack. the only problem for me is that echobit is not around anymore. so im unshure if i should make a hanger or make a replica echobit:confused:
  13. k5redneck
    Jun 24, 2004
    1,000
    mesa AZ
    i know that was nice of me to do that for u...:grin:
  14. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The softest ones (5 spring plus overload) are in light duty 2wd 1/2 ton suburbans (those are what I have). A 3/4 ton truck, or any suburban will have them. I am running the original 5 leaves with no overload.
  15. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    How much more lift, if any, does the 56/57" with echobit flip compair to the 52" with echobit flip?
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is the same amount of lift with 56's as with 52's.
    Harley
  17. jarheadk5
    Mar 6, 2000
    4,389
    PA
    What years???
  18. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    73-91 are the ones I would look for. I think the newer gen II body style still uses 56" but am not positive.
  19. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Move your brackets back 4" and you are golden.
