Who's done the serpentine thing.......
Discussion in 'The Garage' started by Cmoe, Dec 20, 2004.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Who's done it...... Who has + & - to tell us...... I like the look of it and want to find one out of a K5 or a Suburban.... What did you use?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Most everything is a bolt on experience (less one hole that you may have to drill in one of your heads, depends on the head. Scary business as far as I am concerned, lol)
    You will need to do some wiring to get the newer alternator to work, and depending on your truck, you may need to get an AC delete pulley (unless of course you are cheap like me, and just leave the compressor on there).
    If you ask me, its well worth your time and effort, serpentine is just so much better than vbelts, not to mention the fact that the 105 amp alternator is a big boost over the stock 63 amp units...
    Look for DirtyLarry's post near the bottom of this thread, there is a lot of very good information about serpentine setups in here...
    http://67-72chevytrucks.com/vboard/showthread.php3?t=132141
  3. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I did it, it didnt really involve much. Just swapped in a 6.0 vortec and it sort of came with it............................you know you want to.
    Remington
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my burb came factory with it. I however just swapped in an older two piece rear main motor. There is one hole missing on the passenger side head for the bracket. I did not drill and tap it though I heavily considered it. From the factory their are two steel support rods that go from the intake in two different spots to the tensioner assembly. This assembly is directly above the missing bolt so I simply said screw it. No problems yet. My favorite thing about serpentine is simple, one belt that you don't have to adjust. Its SO easy to change a belt(as long as you aren't week), and all you do is carry your old maybe worn one as a spare in case anything happens to yours. Some would call one belt a disadvantage but I must say I really like it. I have a smaller alternator. Its something like 75 Amps. It is a factory piece. My burb came with only two options, spare tire, and 3/4 ton.
  5. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I like the fact that it has a larger alternator. I got the kit from GM Performance parts, because I wanted all new accessories and their kits include all new rebuilt AC Delco accessories.
    As far as the missing bolt on some heads. It says on the instructions that you if the bolt hole is not there you just don't use it. There is a brace for the back of the alternator that ties in with one of the intake manifold bolts, and there is another on the passenger side that ties into one of the exhaust manifold bolts.
    You will have to get a new water pump, because the serpentine setup uses the reverse rotation water pump. If you are using a regular fan you'll need a new one of those in the reverse rotation variety, and IIRC a fan clutch if you're using one of those also.
    I like the serpentine belt setup. I think honestly I like it most for the neat factor.:laugh:
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    A friend of mine recently did the serpentine thing and obtained most of his parts from an S-10. Not sure what year. He has a SBC.
  7. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I also got the kit from gm performance parts. All the brackets worked out good and i was missing one hole in the cylinder head. The only problem that i ran into was the fact that i got two bad alt. In a row so i upgraded to a powermaster and its been good ever since.
  8. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I run a setup from a 91 caprice police car and love it. High output alternator, one belt to worry about, and I think the brackets are way stronger for wheeling than stamped steel jobs.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    GM Performance parts too for me. All worked out very good!
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I really like the serp system I put on my '77. Its from a 1989 suburban. If you buy used, replace the idler pulley and tensioner if there are any questions of their condition.
    One negative not mentioned. The power steering pump pulley must be pulled and installed everytime you want to remove the drivers side bracket. That shouldn't happen very often, but if you don't have the tools, be sure to buy a good quality pulley remover (you wont regret it).
  11. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    My bling bling serpentine :D
  12. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    AK Bandit,
    That is one of the prettiest engines I have seen in a long time. The brackets and pulleys are they the ones from Summit?
  13. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    Thank you...The whole setup is made by March Performance. It came with all the pulleys, brackets, tensioners, and mounting hardware. It wasnt cheap though :doah:
  14. garlicbreath
    May 17, 2003
    1,136
    Denver
    Thats what a friend said also. I have never had to pull my powersteering pump pulley, actually just pulled both brackets off and pulled the motor last weekend with the pulley on the pump. BUT, when I went to the junkyard with a buddy to get him a setup of a newer work truck, we had to pull the pulley? I will have to get his setup next to mine to see why I can leave my pulley on. Maybe the cop car used a smaller pulley? It doesn't look like it though.
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    :bow:
    Have you mounted the belt to see how the alignment is?
    I know my buddy bought a serpentine setup for his BBC with A/C and the alighnment left alot to be desired (although the pulleys and brackets were pretty).
  16. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    Yep, I have both belts mounted. They line up perfectly. After I bought my setup, I started reading about people having issues with the pulleys not lining up. That's alot of coin to throw down for something that doesnt fit right. I even almost cancelled my order. I'm glad I didnt because I couldnt be happier with the setup.
  17. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    You would'nt say that if you have seen as many broken ones as I have. Not sure why they break ( bad tensioner maybe? ). But I've sold a lot of used ones.
  18. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    the car ones are most likly difrent in lots of ways. the truck ones have a hidden bolt behind the pump housing that needs the pump out of the way to get at.
  19. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    On the stock one this is true but the GM Performance one is different. Also note though that with the GM Perf one you can't use the Kilby Enterprises OBA brackets as the ancilleries are in slightly different places to the stock set up.
