Who's got 35" tires, 700R4 and 3.73 setups?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bubba Ray Boudreaux, Oct 28, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Who\'s got 35\" tires, 700R4 and 3.73 setups?
    Have you had any tranny problems? Do you run a cooler? I'm just curious, just thinking about it now since the tires are only less than 10 bucks higher than 33".
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Re: Who\'s got 35\" tires, 700R4 and 3.73 setups?
    Talk to BluBlaz57. He has the same set up and so far no problems.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool if that guy has no probs then maybe i shouldnt have any with the 33's that i wanna run...im a little wiery about the 700 from what ive heard..and i dont have a cooler..should proobly put one in?
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i had the same set up upuntill november of last year...i smoked 3 trannys..in the period of 4 years....the last tranny i pulled out was still runnin and shifting fine..but i figured it was time to go manual and i wont ever go back...screw the slushbox i drive my truck too hard and the tranny just cant take it...i would raduter replace the clutch than the whole tranny
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i would like to switch to a manual but i dont know how hard that would be, seems like there would be a lot of messin around that i wouldnt wanna do..
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I've been running 33" for the last 5 years, not one tranny problem. For the first couple of years, it was 3.4something gears and now it's 3.73.
  7. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    i run 3.73s with a 700r4 and 33 procomp mts i have a coo /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gifler and no problems at all at 70 mph i'm turning 2300 rpms.
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    35" is not 33". Thank you. /forums/images/graemlins/rotfl.gif That's what I'm running now, I'm just doing some research for a possible future purchase.
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I had 35, 3.73's and a 700r4 for a while...Until I managed to SMOKE the heck outa outa the 700...That is why I swapped to a manual...I love the setup sooo much more...I will probably love it more when I get the 454 in there....
    Chris
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Much wheeling and what kind?
  11. Chaz88K5
    2,979
    Stockton/Lodi CA
    its really not that bad of a swap...it took me a good solid 3 days to do the swap...the pedals and hydro linkage took me a day.. and another day to pull the slush box out and get the hole cut in the floor for the shifter...and another day to install the tranny itself and get everything hooked up...but my truck still sat for aother month waiting for axles and for freekin stockton wheel to get my damn beadlocks done...what ever you do...dont buy beadlocks from them!! /forums/images/graemlins/angryfire.gif
  12. bklynlifted
    Feb 4, 2002
    261
    sorry caught the last couple of replys?? /forums/images/graemlins/confused.gif /forums/images/graemlins/pimp1.gif
  13. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I ran 33's, 700r4, & 3.42's for two years with no problems. Most of my driving was highway & it ran great. I would not recommend much offroad or towing with this, however. I've since upgraded to 36's, same tranny (awaiting install of TH400), and 4.11's. This works fine as well, and has been offroad tested & used for towing in the mountains. I just need to get a bigger allowance from my wife to get my 396 rebuilt that's in my garage for a bit "more power"!!!!!
    /forums/images/graemlins/burb.gif
  14. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I'm running 35's, 700, and 3.42's (was 4.56 but destroyed my pinion gear, so this is temp. until I get the 14b in). It's too low a gear for highway. Slows down on small hills. 3.73 would probably do you good. My truck came stock with a towing package, so it already had a cooler. This tranny has been in the truck 3 years and haven't had a problem yet.
  15. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Just food for thought....the 35's that you are thinking of running - you might want to actually measure them. I've measured some 35's at like 33.25
  16. Chaz88K5
    2,979
    Stockton/Lodi CA
    when my 37's were brand new they mesured 35
  17. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I'm running 36" TSL Radials with a 700R4 and 3.73's. I also have the biggest stacked plate style cooler Hayden makes. Seems to run out just fine and has plenty of go from a stop.
  18. BlazinNewTrails
    BlazinNewTrails Registered Member
    Sep 20, 2002
    48
    washington state
    I've got a 350/700R4/3.73 gears. I just went to 35" Mud Kings last night (34" om the truck, I just measured).
    I thought it was gonna suck gearing-wise but so far I'm pretty surprised! It drives fine!
    I'm not drag racing it or anything... and I sure can't tell you about longevity so far... but seat of the pants? It feels fine!
    Greg
  19. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I ran 33's with 3.07's/700r4 for almost 3 years. I also don't run a cooler (not for long though) never had any problems. When I put my 4" BDS lift on I am planning to run 35's with 3.73's. Well see what happens. /forums/images/graemlins/rotfl.gif
  20. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i have 35" tires, 700R4 and 3.73, and have had the truck since april and no tranny problems... the t-case leaked and i took it to aamco and they said the tranny was bad, but it's not bad... so it works fine, and i have a tranny cooler, but it's not installed yet.
