who's got 4.56's,35's and a 700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by efilnikufecin, Jul 24, 2002.
  1. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    who\'s got 4.56\'s,35\'s and a 700r4
    just wondering what kind of rpm's you run at about 75 or 80mph.getting 4.56's installed this week and was just wondering.thanks
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Re: who\'s got 4.56\'s,35\'s and a 700r4
    Scott (4X4HIGH) does..send him a PM,or just wait till later tonight when he replies /forums/images/icons/grin.gif
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Hrm, I'd like to know too /forums/images/icons/tongue.gif
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I run a 350/700 Raptor/4.56s and 35s. Works for me. At 80 mph the RPMs are indeed "up there". I dont have a tach, and couldnt even begin to guestimate what the RPMs are at, but the engine is definitely working. I never go over 75mph... and rarely ever even go that fast, so I dont worry about it.
    J
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    4lo.com has a calculator.
    With true 35" tires, 4.56 gears, and the overdrive of a 700R4 with the torque converter locked:
    75 mph - 2298 RPM
    80 mph - 2451 RPM
    Hey non-OD guys, don't you wish your RPM looked like this?
    (just for reference, my 1 ton turns 3400-3600 RPM at 75-80 MPH!!)
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I do about 3100-3200 rpm's at 75mph. I'd love to swap to a 700 one day. Lower 1st gear and that awesome OD. /forums/images/icons/grin.gif
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I have 4.56's, tires that measure 33.75" diameter (most 35's are not true 35's), and a 700 with lockup. At ~75MPH I turn ~2600 without the converter locked and ~2400 with it locked.
  8. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Can I ask a stupid question? What exactly do you mean by locked up and not. I know you can buy trannies with either lokcup or nonlockup but whate exactly does that mean? Thanks
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I've got that setup right now...I'd say that it's in the 2600 rpm range at 75 and a tad higher at 80 mph...definitely a large increase from my old 3.73s! Man, I used to be turning like 1800 rpm at 60 and maybe 2200 at 75 with those things - it was TOO low to be in the powerband!
    As soon as I get my hydraulic ram steering setup on the truck I'll have to give her a test to see what the real rpms are at speed...
  10. Leadfoot
    Nov 28, 2000
    3,112
    As you know some transmissions have a lockup converter. The 700r4 is one of those transmissions. By nature an automatic transmission is a fluid pump with a hydraulic coupler (a.k.a. torque converter). By design there is some slip built in due to the fluid so when in drive the transmission should turn the same RPM as the motor (such as with a 1:1 manual transmission gear), but the slip in the converter causes the transmission to turn slower and the energy is lost as heat (not good for auto trannies), with a lockup converter, there is an internal clutch (hydraulically actuated) that couples the input shaft of the tranny to the shell of the converter (which is bolted to the flywheel), causing the input shaft to turn the same RPM as the motor, this reduces heat since the converter is not "slipping" and transfers more energy to the rear wheels (more efficient) and therefor at a given speed lowers your engine rpms vs. when the converter is unlocked. Less wear and tear on the tranny and motor.
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have 35''s, 700R4, and 4.56's /forums/images/icons/laugh.gif . Too bad I don't have a tach! /forums/images/icons/crazy.gif , but I will say that right around 75 mph is the maximum that I would maintain for any amount of time. If I wanted to go fast, I would have bought a car /forums/images/icons/wink.gif
  12. efilnikufecin
    Feb 27, 2002
    168
    flint,mi
    thanks everyone.my 3.73 just didn't cut it.i was afraid of burning the tranny up so i'm stepping up to 4.56's.the converter would only lock up going down hill.i know without it being locked they like to heat up and 700's don't take kindly to heat.thanks again.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Just for another data point, I have 700, 35's (probably shy of 34" in reality) and 4.10 gears, which puts me at about 2200 @ 75rpm. 4.10 works well, but 4.56 may be even better. My truck shure scooted with 4.10 and 33"
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had 4.10s and 35s with my 700 and I wasn't happy at all.
  15. Blue85
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Was that with a 305?
  16. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    PM "C'MOE" cause he has a TH350 with 4.56's and 35" tires.I know he really wants an TH700 trans.....the RPM's are killing him.
  17. Living Large
    Living Large Registered Member
    Jun 22, 2002
    40
    Central CA.
    My 1986 GMC with BFG 35 MT, 700R, and 4.56 gears runs 2260 at a corrected speed of 75 mph. Puts the engine right in the torque curve with the combo. This is with a modified trans with the computer controlled lock up removed. The torque coverter is always locked up, which helps to reduce heat and rpm's. It was the best mod that I have done as compaired to the stock 3.08 gears.
  18. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    i ran that combo for a long time with my 1/2 ton set up, it worked pretty well but i live in the mountains and prefer to drive 80+ mph and i wish i had 4.88's. there is nothing wrong with taching 2700 when your covering groud like that, trust me, gearing aint cheap, go as deep as you thing you will ever need the first time, you can always buy bigger tires! /forums/images/icons/grin.gif
  19. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I noticed the same thing crossing the mountains in PA when I brought home my sub. Not alot of climbing power in OD at 65-70.
  20. Grim-Reaper
    7,385
    Atlanta
    Well my speedo is off. When I'm turning 2800-2900 RPMs I'm still getting passed with TH350, 4.10's a BFG KO 35's. Course they drive like idiots here. In my Supra with the cruise on 80 mph I'm only passing half the cars on the road. the other half is passing me doing 85-90. Hehehe They don't call 285 (loop around Atlanta) the Atlanta Autobahn for nothing. OD would be nice. That's why I went 4.10 cause of the speed they run around here. Had to be able to go fast enough not to get run over. Really felt like I lost a ton of power when I went from 32's- 35's /forums/images/icons/smile.gif After riding on the hwy in BigJbears truck and listening to the engine wound out and getting passed by 72 beetles and he even has lock up converter I knew 4.56 was going to be a little high for my tastes. Now if I had a 700R4...4.56 all the way. It's just right.
